re-adjusting valves
Old Jul 27, 2005 | 10:49 AM
pawcio's Avatar
Car: GTA 89
Transmission: TH700
Axle/Gears: BW 9 bolt
re-adjusting valves
Hi all
I need to re-adjusting valves on my motor. Rebuild motor, I adjusted the valves but too loosely and when motor get warm, operating temperature they are clicking
So I turning when pushrods stop walking up and down and...
hmm many sources announce different ways to do 1/2turn 1/4turn or one full turn? Which is good and when? The engine is 350TPI
thanks!
Old Jul 27, 2005 | 11:39 AM
kevinc's Avatar
Car: 1982 Z28
The lash (preload actually) needs to be adjusted when the lifters are on the cam's base circle, not a lobe ramp.
There's a procedure here and in the manual if you dig around, basically bring cylinder 1 to top dead center firing and you can adjust some of the valves, then bring cyl 6 to TDC and you can adjust the rest.
I always used 3/4 turn past zero lash when I had my L98 engine and it was a happy camper.
Old Jul 28, 2005 | 12:28 AM
pawcio's Avatar
Car: GTA 89
Transmission: TH700
I used a 90degrees method but when I assembling heads I only remove pushrod walking and do not turn any degree more :/ and when to motor warm I see a negative effect of that
today I'll set a zero lash and start with 1/2 turn more
I hope will be good if no i'll try 3/4
regards
Old Jul 28, 2005 | 08:59 AM
NastyL98_T/A's Avatar
Car: '88 T/A and '90 T/A
Engine: LB9/383
Transmission: T5/700R4
On a particular cylinder, as the EXHAUST is OPENING, adjust the INTAKE. As the INTAKE is CLOSING, adjust the EXHAUST. This makes sure that the valve you're adjusting is on the base circle. Remember that as metals get temperature in them they expand. If you're doing this on a cold motor you should go zero lash plus 90*. On a warm motor I would go that 90*, plus another 1/8 of a turn.
SPEEDY Z28
Brakes
16
Apr 18, 2016 02:46 PM
sleprock
Sep 24, 2015 04:33 PM
HikoriYami
Sep 21, 2015 07:11 PM
355tpipickup
Sep 13, 2015 11:35 PM
sandman92084
Sep 12, 2015 10:27 PM
