Older intake on newer heads, i think i messed up...
Old Jul 27, 2005 | 12:57 PM
ChevyRacer's Avatar
Car: 86 Camaro Iroc-Z
Engine: 355 TPI
Ok, the problem is just as the title reads. I tried to modify my intake for the newer style heads. The 4 middle bolt holes as far as i was told are to be extended more towards the edge of the intake.
I got the largest bit i had and first enlarged the bolt hole as much as possible by wobbling it around, my first mistake, atleast IMO. becuase i went too far in some area's and cut into the oil galley area of the facing. I think i'd be able to remedy this up, but now the problem enlies, how the heck do ya do ya enlarge the hole properly?
It seems as if i should just cut that part of the intake facing off all the way top the end to allow the bolts to go in freely...
does anyone have any pics of their modified intake?
Old Jul 27, 2005 | 02:27 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Oil gallery area? There's no oil passages in the intake.
Old Jul 27, 2005 | 07:31 PM
ChevyRacer's Avatar
Engine: 355 TPI
the are under the intake, i umm.... kinda cut the flange down so far, that the galley and bolt hole are one and the same... I ummm cut in the wrong direction,
Old Jul 27, 2005 | 07:36 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
What galley are you talking about? There's no oil passages in the intake, only coolant, exhaust and unburned fuel/air.
Old Jul 27, 2005 | 07:39 PM
ChevyRacer's Avatar
Engine: 355 TPI
wait i meant the lifter galley, not oil, whoops, the area above the lifters...
Old Jul 27, 2005 | 07:50 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Did you put the intake on to varify this? The area on the intake mounting flange and the heads is pretty big. It would be extremely difficult to do this. It would require extending the bolt hole an 1" or more.
FWIW, I adapted a regular pre 86 intake to a set of aluminum LT1 heads. I had to actually redrill several holes up to 1" horizontally, along with re-angle the bolt holes to fit the different bolt angle o fthe LT1 heads.
Old Jul 27, 2005 | 08:14 PM
ChevyRacer's Avatar
Engine: 355 TPI
yep i'm sure, i can take a pic tomorow maybe, but the flange was royally screwed.
Today i bought a fully ported and powdercoated modified intake. It was $50 including shipping. Only becuase the guy lives 40 minutes from here, but i dont have a car to drive to him at the moment.
SLNTSCPE
Aug 22, 2015 09:15 PM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
theurge
Aug 21, 2015 12:46 PM
89mulletbird
Aug 12, 2015 07:08 PM
