How to remove wires from TPS connector?
Old Jul 30, 2005 | 11:53 AM
trueburton's Avatar
Car: '88 Red Trans Am w/ T-tops
How to I get the wires out of the connector? I pulled the Connector off the TPS and removed all the rubber seals and pulled the clip off that covers the back side but the wires are still stuck in there.
Old Jul 30, 2005 | 12:20 PM
luke4907's Avatar
Car: '89 Trans Am GTA
Engine: TPI350
Axle/Gears: BW 3.27s
not sure how to remove the wires, you could always remove some of the insulation from the wires you need to get access to... or if you are using a voltmeter to get a reading on the wires then just stick your test leads into the slots where the wires go into the connector.. it's a tight fit but that's always worked for me... what are you trying to accomplish?
Old Jul 30, 2005 | 03:36 PM
trueburton's Avatar
Replacing the TPS connector.
Old Jul 30, 2005 | 10:14 PM
brutalform's Avatar
You need a weather pack wire removal tool. Any parts store should have one.
Old Jul 31, 2005 | 10:25 AM
Vader's Avatar
Brutal has you covered. Look for one of these:
Attached Thumbnails How to remove wires from TPS connector?-pinrejectiontool.jpg
Old Jul 31, 2005 | 05:06 PM
trueburton's Avatar
I see... and exactly how do I use that thing?
Old Aug 1, 2005 | 10:40 AM
92blue's Avatar
Former Sponsor
Car: 1992 Camaro RS
Engine: Yet another 350 TPI
Transmission: Borg Warner 6 spd
It has a round "tube" like end that you stick in over the terminals from the TPS side of the connector. You gently push it in, and once it goes in all the way, pull the wire out.
Needless to say, you aren't to be able to get the seals you removed back on. When they crimp the wire on the terminal, the seal is secured onto the terminal during the process.
Let me know if you need new terminals, seals, or the connector itself. I have them new.
Old Aug 1, 2005 | 09:38 PM
trueburton's Avatar
How do I know if the terminals are bad?
eightsixseven
Dec 16, 2024 01:50 PM
specialized
Jun 18, 2022 09:26 AM
perZ
Aug 15, 2015 01:17 PM
stalkier
Aug 13, 2015 12:59 PM
3rdgenparts
Aug 8, 2015 07:09 PM
