HP gain using elec pump vs mech pump
Car: 88 Camaro
Engine: 310 LG4
Transmission: 700R4 w/2200 stall
Is there any HP gain from using an electric fuel pump over a mechanical fuel pump? Since the cam is used to push on the rod that activates the mechanical pump, does that help the motor in anyway by not having to do that?
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Not really. A mechanical pump doesn't use much power anyway. Also when swtiching to an electric pump, the power to operate it has to come form somewhere. Guess where, the engine, which turns the alternator.
I'm guessing that a FP only uses 60-100 watts, ~.1hp anyway.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You could try a lighter weight fuel pump pushrod if you want to recover some of that .1 HP.
