cracked neck of fuel tank.... please help
Old Jul 30, 2005 | 01:26 PM
bigchief's Avatar
Car: 1989 Firebird Formula
Engine: 5.7L 355 TPI
Transmission: 700 R4 with TCI rebuild kit and valve body mods
no pressure in gas tank when i unscrew the cap b/c the neck is cracked...... is this dangerous??? im getting no leaks, but i do smell gas in the back of the car after driving. the only way i can fix it is to drop the tank and weld the neck where it is cracked.
basically i just want to know how this can effect the cars performance, or what else it can effect. thanks!
Old Jul 30, 2005 | 01:36 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
I wouldn't weld anything fuel related...
Old Jul 30, 2005 | 02:16 PM
Fire"Dutch"Bird's Avatar
Car: '88 Firebird Formula 350
Engine: 350 (5.7 TPI)
Transmission: auto 700R4
Axle/Gears: BW 9-bolt L.S.
Go to a GM dealer and have your VIN chequed for the infamous fillerneck recall, it was for '89 cars and up, so maybe you're lucky!!
I cured the leaking fillerneck on my car by putting epoxy sealer around it, it does the job well!
Just unbolt the straps that hold the tank in place, and you have just enough space to reach the leaking spot(s).
It doesn't hurt your car performances at all, but is potential dangerous in case of fire...!!
Old Jul 30, 2005 | 02:38 PM
91ChevyRS's Avatar
Car: 1998 Volvo S70
Engine: B5254S Engine
Transmission: Automatic
Axle/Gears: It's a volvo?
I am having almost the same problem as you except I do get a pressure noise from the gas tank when I fill up...problem is after I am done filling I smell gas at the back of the car after I am done driving. I really dont know what it is and I am trying to figure it out.
I made a topic on this a short while ago but no one responded...
Old Jul 30, 2005 | 04:22 PM
NoItsNotForSale's Avatar
Car: 87 & 89 Iroc's
Engine: 5.0 - 5.7
Transmission: 700R's
Axle/Gears: 2.77 - 3.70
The recall does not cover 89's and my 89 had the same problem.
Thanks JB weld.
Old Jul 30, 2005 | 04:57 PM
The recal is for Firebirds made between 10/01/1989 til 08/01/1992
Look at:
http://www.isertive.com/php/NHTSA/au...Model=FIREBIRD
Old Jul 31, 2005 | 02:55 AM
bigchief's Avatar
well, i appreciate all your help. thanks a lot. i guess im just gonna end up dropping the tank, and having my dad weld the crack wherever it may be. (i will obvioulsy empty the tank first.......) anyway, thanks again about the recall information, ill give the dealership a call tomorrow and see if they say anything about that.
Old Jul 31, 2005 | 04:07 PM
83CAMAROMAN's Avatar
Car: 1983 Camaro Sport Coupe
Engine: 1986 305 C.I.D. Bored .030 over
Transmission: TH350 W/Shift Kit
Axle/Gears: 3:08
epoxy...will fix it just fine and save ya time and energy
Old Jul 31, 2005 | 05:30 PM
bigchief's Avatar
i've also heard of a cement glue that they sell, supposedly its very good to use on things like that to seal stuff. maybe ill pick up some of that. thanks again guys
Frozer!!!
Jan 19, 2024 04:55 PM
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
kyleb24
Aug 15, 2015 08:24 AM
