shakey pontiac firebird
Old Jul 30, 2005 | 08:23 PM
andi21's Avatar
Car: 1999 Pontiac Firebird
Engine: 3.8/V6
Transmission: Automatic
I have a question... I have a 1999 Pontiac Firebird. In the morning the car was driving fine as usual...but in the evening time when I got in and started it up to go down the rode, about 2 minutes after driving its started shaking pretty heavily. It also sounds alot louder when driving and while in park, and while your foot is on the brake. When the car is in reverse it shakes harder, and when you slow down towards a red light and take your foot off the brake it shakes the hardest.... It's seems as though it has also lost power, when started to go from a stop...
Any clue as to what this could be?? No smells or fumes are coming from the car..just the sound and the erratic shaking...
Any help would be appriciated... Also SES is on...when it first started yesterday it was solid..now it is flashing...
Thanks guys...
Old Jul 30, 2005 | 09:43 PM
KintaroOe's Avatar
Car: '91 bird '87 Z28 '86 T/A
Engine: LO3 LG4(ls1 in works) 350
Transmission: 700R in all
Axle/Gears: wimpy 10 bolts
i had a fiero with a similar problem although i dont know if applies to you, but check to see if your TCC solenoid is bad.
Old Jul 30, 2005 | 09:45 PM
andi21's Avatar
Engine: 3.8/V6
I'm sorry..but what is that? Whats it do??
I'm sorry...obviously I'm female... not TOO car inclined...but I really am trying...
Thanks for the response...!
Old Jul 30, 2005 | 10:02 PM
KintaroOe's Avatar
if i remember correctly, it is the solenoid that i believe that it actually locks up the torque converter and if its starts to go bad, it produces some of the symptoms that your describing.
Old Jul 30, 2005 | 10:14 PM
andi21's Avatar
Engine: 3.8/V6
Yup...not familiar with that part....is it quite costly to fix..if you know..I'd appriciate it? Also, anything I can have checked to verify that is it before I take it to a mechanic that may try to rip me off???
Also, someone else told me it could be spark plugs need to be changed..is that also possible??
Thanks again...
Old Jul 31, 2005 | 12:18 AM
dahaus's Avatar
Car: 1985 IROC
On the right side of your transmission, just above and behind the shift linkage, there is a four pin square connector, with a few wires. Disconnect it and drive. See if your problem is fixed and let us know.
Old Jul 31, 2005 | 12:33 AM
83CAMAROMAN's Avatar
Car: 1983 Camaro Sport Coupe
Engine: 1986 305 C.I.D. Bored .030 over
Transmission: TH350 W/Shift Kit
Axle/Gears: 3:08
The spark plug possibility would be the easiest thing to check..just pull one or two out and check em out....if they are fouled or just really dirty...they may lead to a problem similiar to yours....
I'd say check that out first....
do you knwo how old the plugs are in your car?
Old Jul 31, 2005 | 05:32 PM
andi21's Avatar
Engine: 3.8/V6
so got the codes.. it says DTS (codes)
p0306
cylinder 6
Misfire detected
was told could be spark plug, wire, or ignition coil..?
could it be anything else??
Bought all those parts anyway to have all three replaced..but could it be anything else?
Thanks again guys...
Old Jul 31, 2005 | 05:44 PM
Axle/Gears: 3:08
usually it the wire or the plug itself....
Old Jul 31, 2005 | 05:58 PM
roughskinjrz's Avatar
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
this happened to me while i hit the brakes, the whole car would shake so bad i felt something was gonna brake.
i had to actually replace the rotors
Old Jul 31, 2005 | 06:01 PM
andi21's Avatar
Engine: 3.8/V6
no, this isn't happening when I brake...it's right before I brake, or let off the brake., or drive., reverse., idle. It is always shaking..it doesn't have anything to do w/ the brakes.. I just put brake pads on it last week anyway...and the ses light is on...thanks anyway though....
Old Jul 31, 2005 | 06:07 PM
sellmanb's Avatar
Car: '86 Berlinetta
It's hard to diagnose a car that hasnt been tuned up recently. After that's accomplished you can see where you're at.
Old Jul 31, 2005 | 06:09 PM
Axle/Gears: 3:08
sellmans got a point..i know your trying to get to the bottom of this particular problem but after this is solved go ahead and do all the basic mainteneance stuff ...if your not sure what needs to get done or havent had the car too long just do a search for on it..vader did a good write up a long time ago on what to do to a new car...well new to you car...
Old Jul 31, 2005 | 07:21 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
These late model cars are very hi-tech and hard to diagnose without the right test equipment. You could spend a whole bunch of money and not get it right. With this engine it is very common to have a coolant leak into an end cylinder through the intake, new ignition parts won't fix it but an $800 intake R&R is required. Hopefully this is not your problem but I'd sure suggest taking it to an expert and not throw a bunch of money at it without knowing what's wrong. I'm a pretty good hammer mechanic but I wouldn't hesitate to take mine to someone up to date on it.
Old Jul 31, 2005 | 09:32 PM
2BoltMain's Avatar
PO306 is a misfire on #6 cylinder.
If I'm not mistaken, that car has individual coil pasck for each cylinder. I could be wrong, it's been awhile since I popped the hood on of of those cars.
Here's what I would do.
Take the coil pack off of the #6 cylinder, and swap it with the #4 coil pack, if you get a code that's PO304 misfire #4 cylinder. Then you know your problem is a coil pack. I think those are about 55-60 bucks.
While you're at it you might as well change all your spark plugs as well.
Hope this helps
Chris
Old Jul 31, 2005 | 09:55 PM
andi21's Avatar
Engine: 3.8/V6
cool thanks guys...got the coil pack for $20 at advanced auto..and I'm having all spark plugs changed...
appriciate all the help boys....
Old Jul 31, 2005 | 10:04 PM
dahaus's Avatar
Car: 1985 IROC
I am an idiot!!!!! I just now realized this isn't a third gen. I was giving info for an 700r4 not a 4L60
Old Aug 1, 2005 | 04:39 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
4L60-E... The poster might have more luck on a forum that deals with 4th gen cars, seeing as how no thirdgen came with OBD-II, much less a DIS 3.8L V6...
Old Aug 2, 2005 | 03:59 PM
Tom 400 CFI's Avatar
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
Or a forum where people give out systematic diagnostic advise rather than a bunch of "shoot from the hip", WAG's. What a terrible thread this has been.
Old Aug 4, 2005 | 07:02 AM
andi21's Avatar
Engine: 3.8/V6
Turned out to just be the the wire...got it fixed car is running great...thanks guys!
jhawkeye
May 25, 2022 06:33 PM
1Aauto
Sponsored Vendors
Nov 23, 2015 02:17 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
1Aauto
Sponsored Vendors
Aug 26, 2015 02:18 PM
1Aauto
Sponsored Vendors
Aug 26, 2015 02:14 PM
