305 TBI Blazer Heads
Old Oct 3, 2001 | 10:09 AM
camaro6spd's Avatar
The engine i have in my camaro is a 1990 K Blazer 305 that was TBI, Could anyone tell me what heads are on this thing and are they the same at the LB9 heads, I have the LB9s but the K blazer engine has a total of 100 miles on it(has 8 when i bought it for $900)
-Tom
1987 Black 305 TPI 5spd IROC, seems to be fully loaded, but can't find RPO codes.
AIM: IROC 5spd
Old Oct 3, 2001 | 11:00 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
AFAIK there were no 305s in K Blazers in that year... it should have been a 350. But in either case, if it's a factory TBI motor, then the heads suck for high perf use. They are a far worse design than the ones used on a TPI motor. They'll be the "swirl port" type, with the big "ramp" obstruction in the intake port.
ICON Motorsports
[This message has been edited by RB83L69 (edited October 03, 2001).]
Old Oct 3, 2001 | 11:02 AM
TransamGTA350's Avatar
Car: '89 GTA
Engine: ZZ6TPI
The heads are the same as far as bolt pattern, chamber size, and valve size. The Blazer heads have the swirl port in the intake bowl, and the Camaro heads may or may not have them. Since you have the heads from the Camaro off already, take one of the intake valves out and look in the bowl. If it is half blocked off, then it's a swirl port head and it's the same as the Blazer head. If it's open, then it may be worth rebuilding, porting and polishing and putting on the Blazer engine that's already in the car.
Another thing is the cam. The cam that was in your Camaro engine is much better than the one in the Blazer engine. Since it's a roller cam, milage doesn't matter and if it were mine, I'd swap it.
89 Transam GTA, 350TPI, auto, 3.27 rear, dual cats, gray.
Magnaflow cat-back,
K&N open element,
Best E.T. 14.63@95mph
Old Oct 3, 2001 | 02:53 PM
camaro6spd's Avatar
i have the cam thing listd in the TPI i think. Yeah my G92 cam was destroyed on the old engine...#8 was complety blown up piston in uncountable pieaces, rod bolts bent at 90*, con rod in 4 parts, dist gear busted, cam with dents in it...etc etc it was bad, but the heads were UNTOUCHED. Looks like the guy before me really had no idea what he was doing.
xkingcodex
Feb 12, 2020 07:43 PM
pimp2303
Jul 27, 2017 02:03 PM
92purpz28
Aug 11, 2015 02:30 PM
