Humming...
Old Jul 31, 2005 | 09:31 PM
Gr89RS's Avatar
Car: '02 Z06
Humming...
When im cruzing between 40-50 mph, the car makes a humming/whining noise and i have no idea what it is or where it is coming from. It will stop if i take my foot off the gas, but as soon as i press the pedal, there it is again. It only does it at these speeds, no other time. The car is a 91' Z28 305 TPI auto, any help is appreciated.
Old Jul 31, 2005 | 10:42 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
If you are in park and you rev the motor does it still do it?
Old Jul 31, 2005 | 10:58 PM
Gr89RS's Avatar
Car: '02 Z06
Nope not one bit.
Old Aug 1, 2005 | 03:54 AM
BRobinson's Avatar
Car: 82 Camaro
Transmission: TH-350
Axle/Gears: 3.08
Does it go away if you step into it, and the tranny kicks down for passing?
Old Aug 1, 2005 | 03:25 PM
Gr89RS's Avatar
Car: '02 Z06
No it only does it if my foot is just slightly pressing the gas.
Old Aug 2, 2005 | 05:25 AM
Difflock's Avatar
Car: VIN=85 T/A, CAR=82/3 T/A gfx, go figure. She's a T/A anyway!
Engine: 5.0, Holley 600 cfm 4-barrel
Transmission: THM350 ??
Rear wheel bearings? Pinion bearings? Just guessing, but it may help.
Mark.
Old Aug 4, 2005 | 03:18 AM
BRobinson's Avatar
Car: 82 Camaro
Axle/Gears: 3.08
Sounds like the tranny. Try going up a steep hill at that speed, and lightly press on the gas. I'd bet anything it will sit and shift back and forth between gears, and make a horrible racket. How many miles do you have on the car?
Old Aug 4, 2005 | 03:28 AM
Gr89RS's Avatar
Car: '02 Z06
180k
Old Aug 4, 2005 | 04:13 AM
Gr89RS's Avatar
Car: '02 Z06
If it is indeed the tranny, how bad of damage do you think there is?
Old Aug 5, 2005 | 03:04 PM
Gr89RS's Avatar
Car: '02 Z06
bump
Old Aug 25, 2005 | 08:55 PM
chevy_camaro_ss's Avatar
Car: 1989 Camaro RS
Axle/Gears: 3.23 posi
I have the same problem with the humming noise. It only does it when I I press the pedal even if it is lightly pressed. When I let go it stops the humming. Did anybody figure out what it was. My problem started when I switched out the rear end for a posi unit from a '94 z28 with 3.73 gears.
Old Aug 25, 2005 | 10:40 PM
Gr89RS's Avatar
Car: '02 Z06
nope still havent fixed it yet. my car came with the stock posi 2.73 rear if that helps at all?
Old Oct 3, 2005 | 12:23 AM
BRobinson's Avatar
Car: 82 Camaro
Axle/Gears: 3.08
ATRATB256A JAN 96 A/T - 4L60/700R4 Rear Planet Failure/Lack Of Lube
ATRATB334 JAN 96 A/T - Delayed Forward Engagement/Burnt 3-4
932287A JUN 93 A/T - Click or Whine in Third or Fourth Gear
Found these on the preliminary search at Alldata.com, but I don't have a subscription.
