Water question
Old Oct 2, 2001 | 01:20 PM
V12Kid's Avatar
Water question
anyone here use that additive for your coolant thats supposed to help it cool better, think its called water wetter or something? If you have, have you noticed a difference or is it harmful? thnx for your input guys!
Old Oct 2, 2001 | 04:16 PM
Fire"Dutch"Bird's Avatar
Car: '88 Firebird Formula 350
Engine: 350 (5.7 TPI)
Transmission: auto 700R4
Axle/Gears: BW 9-bolt L.S.
It's called Redline Watter Wetter.
I'm using it for years now,engine runs a bit cooler for sure!
Old Oct 3, 2001 | 03:41 PM
82camaro's Avatar
Car: 82 camaro SC
Seemed to help in mine.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, currant red metallic paint. Lots of other stuff...
82camaro
NiG
Sep 2, 2015 06:54 AM
Bubbajones_ya
Aug 28, 2015 02:17 AM
lakeffect2
Aug 23, 2015 08:44 AM
redmaroz
Aug 16, 2015 11:40 PM
