CAR HAS NO BALLS
Old Oct 3, 2001 | 10:33 PM
camzcruizer's Avatar
CAR HAS NO *****
I NEED ****ING HELP MY 90 5.7 IROC HAS LOST ITS *****!!!!!!!!
first it wouldnt idle, so i changed my EGR valve.
Then, i fixed it and it idles fine, but when i drive it, it has no power, won't go over a certain RPM, and kicks in and out of gear real hard, and sounds like something in the exhaust is clogged. HOWEVER, i was told the CATS may be clogged so i installed brand new let me repeat 300 dollar DUAL cats and the exhaust shop looked in the exhaust and it was all free so its not the exhaust. WHAT THE **** IS WRONG WITH MY CAR!!!!!!!!! HELPPP ITS MY DAILY DRIVER AND IM SICK OF GETTING RIDES EVERYWHERE!!!!! THANKSSSSSS
Old Oct 3, 2001 | 11:15 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
Whats the fuel pressure?
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
and 2 POS commuters...
R.I.P. #3
"He can see air"
Old Oct 3, 2001 | 11:26 PM
i have no idea, i imagine its getting enough fuel, its got brand new gas lines and fuel filter on it. perhaps its a computer problem when i changed my EGR????????
Old Oct 3, 2001 | 11:28 PM
RIP EARNHARDT 3333333333333333333333333333333333333333333333333333333
you rootin for the kid or harvick now?
Old Oct 3, 2001 | 11:38 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
your pump might be goin bad....
check pressure.
Harvick
Still not the same...never will be.
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
"He can see air"
[This message has been edited by Engineboy (edited October 03, 2001).]
Old Oct 3, 2001 | 11:47 PM
pianiy's Avatar
My guess is the pump as well... I know, I've gone through it THREE times in two Firebirds
~Luke
'91 Firebird :: L03/700R4 ::
Mods: Catco cat - Flowmaster 80 series - B&M Shift kit - TA tail lights - GTA rims - K&N - MacEwen guages
Stereo: Pioneer DEH-P8200R - Cadence 4x6's - Pioneer 6x9's - Kicker amps - Kicker 10" CompVR
Firebird parts - Selling an '80 Firebird for a friend
Moderator of tranny board over at TransAmGTA.com
Old Oct 4, 2001 | 11:13 AM
how do i check the fuel pump pressure
where is the fuel pump anyway?
Old Oct 4, 2001 | 11:15 AM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
Pump is in the tank.Rearend and exhaust need to be out of the way,first.
Old Oct 4, 2001 | 11:31 AM
noooooooooooooooooooooooooo damn this sucks is there any way i can check to see if the pump is bad or how can i check if im getting any fuel pressure?
Old Oct 4, 2001 | 11:33 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Car has no *****? sipmle: its a GIRL
1983 Firebird
TH700R4 Auto
Small Block 400
LG4 ECM, Intake, Carb, Distributor, etc.
Soon to be non-computer.
Clarion Head Unit 45X4
2 Pioneer 400W 12" Subs
Third Gen Performance
"A four cylinder is half an engine."
"Ponies can run, but birds can fly..."
[This message has been edited by Ward (edited October 04, 2001).]
Old Oct 4, 2001 | 05:27 PM
GOLD85's Avatar
hock up a fuel presure gage to the sharader valve on the fuel rail. it should read 40 psi if its any thing less u need to replace your pump
when the green flag drops the bull$hit stops
pulled the 350 to make way for the 406 wich is in the machine shop. got a comp 282S bump stick with 1.6 rockers. looking at differnt heads right now.Perfomer RPM and holley 650 DP, headers and 3 inch exhust. 3000 stall converter and a built 700r4. shotin for mid 12s next summer
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
NBrehm
Aug 5, 2015 07:57 PM
