Question > Vib damper install.
Old Aug 3, 2005 | 07:13 AM
HawkeyeGT's Avatar
Car: 1982 Chevrolet Camaro Z28,
Engine: 5,0l
Transmission: TH 350
Hi,
gotta quest.
See the pics?
Is that the right position? Or must I go a bit further?
Don't know how it was, before removing. Was a few month ago.
Thx
Hawk
Old Aug 3, 2005 | 07:14 AM
HawkeyeGT's Avatar
Engine: 5,0l
Another one
Old Aug 4, 2005 | 05:06 AM
HawkeyeGT's Avatar
Engine: 5,0l
No one?
Old Aug 4, 2005 | 10:10 AM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
You just need to make sure the damper hub is seated against the crankshaft timing gear. Just go until it stops moving in.
Old Aug 4, 2005 | 10:18 AM
ssean92's Avatar
Car: sold
i would have to say it needs to go in fartherit should be about a 1/4 of an inch from the timing chain cover
Old Aug 4, 2005 | 12:39 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Yup. Keep it going till it cant go no more.
Old Aug 4, 2005 | 01:31 PM
HawkeyeGT's Avatar
Engine: 5,0l
Well, thats my problem.
I don't have the mounting tool for that.
I did with a rubber hammer, and the center screw. And right now I'm at a point, where I would say the noise of the center screw isn't sounding very trustfully .
Do I have any great disadvantages, when not sittin' in right position?
Old Aug 4, 2005 | 02:26 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Yes... Rent a tool from autozone and put it on the proper way. Once your done, return it and get your money back.
Old Aug 4, 2005 | 11:50 PM
TheMysticWizard's Avatar
Car: 1987 Firebird Trans AM
Engine: 383 TPI...very soon
Transmission: TH700R4
You can go to a hardware store and buy a bolt that is 6" long, and a nut that goes on that bolt... make sure it's the same thread as the crank (7/16-20?) and then use your washer from the damper...
put the nut on the bolt, put the washer on, then screw the bolt all the way into the crank, then "loosen" the nut to force the damper on.
That's how I did mine, now I have a tool for if I ever need to do it again, and it cost me a total of maybe $1.50.
MoJoe
Sep 15, 2015 12:50 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
formula_novice
Aug 18, 2015 08:48 PM
redmaroz
Aug 16, 2015 11:40 PM
