need help- girdle/oil pan problems
Old Aug 3, 2005 | 11:55 AM
TPIs-10's Avatar
Car: 88 S-Dime
Engine: 388
here is the deal: i have a roller 350 block that i am in the process of building/stroking to replace the tired 406 that's in my s-10 right now. i bought a main girdle for the 2 bolt- and the stock late model oil pan won't fit around the girdle. it's my understanding that girdles always require some "massaging" to get them to fit correctly- is this true? also- will the 400 oil pan i have now fit on the late model roller 350 block i have? if so- is it any wider or have the strengthening ribs that the 350 pan apparently has. i can't see any of this first hand as one of my friends that teaches auto shop at a college 2 states over is doing the machine work for me. he is a mopar guy- so he doesn't know much about the chevy oil pans. he says we either need something a little wider or no strengthening ribs in order to get the pan to clear- or at least clear with a less grinding involved. he also said the oil pan that he has there at the shop for a late model roller slants inward a little- and he thinks the 400 pans don't do that- anyone want to confirm this?
Old Aug 3, 2005 | 12:08 PM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Oil Pan won't work, the dipstick is on the wrong side.
Not sure about the rest....
Old Aug 3, 2005 | 12:10 PM
TPIs-10's Avatar
Car: 88 S-Dime
Engine: 388
it's in an s-10 - so what works and doesn't work in a camaro doesn't really mean a lot in my situation. there is already a 400 in the truck now- and everything is functional- including the dip stick
Old Aug 3, 2005 | 12:13 PM
ploegi's Avatar
Engine: 5.7 TPI
The oil pan is formed where the dipstick enters thru the block, the 400 has this on the drivers side, the 350 will have it on the passenger side. Does not matter what it sits in, it still will not fit.
Old Aug 3, 2005 | 12:14 PM
TPIs-10's Avatar
Car: 88 S-Dime
Engine: 388
ahh- didn't know that. not the news i was wanting- but thanks for the insight.
what is the widest stock replacement type oil pan out there then? i don't want/need some high $$ 42 quart pan- i just want a stock replacement type.
someone972
Aug 30, 2015 12:52 AM
JHX
Aug 29, 2015 02:30 PM
downsouthboy
Aug 29, 2015 11:29 AM
Navy8125
Aug 21, 2015 09:32 AM
MY87LT
Aug 17, 2015 08:43 AM
