New cam didnt come with Lube? Y?
Old Oct 5, 2001 | 02:11 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Is it because its a Hyd. Roller?
Old Oct 5, 2001 | 02:59 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
No special break-in lube required on a roller...
I wash the cam with spray carb cleaner, use a thin smear of white lithium grease, flush the lifters in lacquer thinner, then soak them in oil.
ICON Motorsports
Old Oct 5, 2001 | 03:04 PM
Dan87IROC-Z's Avatar
Thats right, no lube requiered for hydraulic roller cams. I just coverd the lobes and such with some oil and slid it right in!
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End with 2.77:1 Gears.
Current Mods: LT4 HOT Cam, Comp Cams 1.52:1 Roller Rocker Arms, Accel High Flow TPI Baseplate, Edelbrock TES 1 5/8" Headers, Catco 3" High-Flow Catalytic Converter, Hooker 3" Aerochamber Cat-Back System, Transgo Shift Kit, Performance Resource Chip, Accel Ignition, K&N Filters, Jet TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET: 14.32 @ 97.7mph
(corrected for elevation)
Old Oct 5, 2001 | 06:16 PM
ede's Avatar
ede
i do like rb and clean it with brake clean but i use moly lube. i know i don't need to but it doesn't hurt and it makes me feel a lot better. if you want to go with regular assembly lube lubriplate 105 is very good stuff and is easy to find in most parts stores and industrial supplies.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Jorlain
Oct 8, 2015 01:57 AM
64Chief
Sep 12, 2015 08:05 AM
Randomtask2
Sep 7, 2015 05:06 PM
BOOT77
Sep 5, 2015 03:55 PM
