Block Learn
Old Oct 6, 2001 | 06:35 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Block Learn
After going into closed loop and have the engine warmed up it reads 128/128 at idle and when on the highway at about 2100 it read 135/127-131 is this normal?
Old Oct 6, 2001 | 07:51 PM
drive it's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Mkos1980:
After going into closed loop and have the engine warmed up it reads 128/128 at idle and when on the highway at about 2100 it read 135/127-131 is this normal?</font>
Nope, it should be 128 blm and int +/-4 or so. But...what year do you have? What code are you running? Does it have a hwy mode?
86 406
Old Oct 6, 2001 | 10:49 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Its an 89 350 TPI, I have no idea what mode. I just pluged in my OTC 2000 and hit the block learn mode. when i let off the gas at 2100 it reads 117/128
Old Oct 7, 2001 | 12:02 AM
drive it's Avatar
Its an 89 350 TPI, I have no idea what mode. I just pluged in my OTC 2000 and hit the block learn mode. when i let off the gas at 2100 it reads 117/128</font>
With an 89 it'll be "6E" tdf. So yes, you have a mode that leans it out at "cruise" and also a decel mode that will cutoff fuel when you let off. When checking your blm's you want steady acceleration, smooth, not over about 65% throttle, avoiding sudden transitions and hwy mode. With sudden transitions etc. it will bounce the blm around. Hope this helps.
86 406
Old Oct 7, 2001 | 05:28 PM
Damon's Avatar
Sounds normal. Never had one that ran 128 all the time. I have come to accept anything +/- 10 (118 to 138) as pretty damned good.
My 94 LT-1 runs block learns in the 118 range (stock programming is a bit rich).
My brother's 87 GTA ran in the 133-135 range (stock programming a bit lean).
His carbureted LG-4 runs in the 120-122 range but varies considerably with weather conditions.
Not saying your engine will be the same, but wanted to give you an idea what I have experienced.
3GZJerry
LSX and LTX Parts
Oct 14, 2015 05:17 PM
86z89iroc
Oct 5, 2015 01:04 PM
Jonas Earl
Sep 27, 2015 07:39 AM
GTAman
Sep 26, 2015 02:01 PM
RyanJB
Sep 14, 2015 03:39 PM
