filler neck
Old Aug 7, 2005 | 04:09 PM
Borsty's Avatar
Car: 89 Trans am
Engine: TBI 350 HO Vortec heads
filler neck
i cant get my tank out without cutting this annoying *** filler neck.
is cutting it and puttin a small section of hose a bad idea?
my dad does, but i think hes just being a nancy.
Old Aug 7, 2005 | 07:36 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Listen to your Father...then get a manual or search abit more on how to drop the tank...or search for "fuel pump replacement". etc.
Old Aug 7, 2005 | 07:47 PM
Borsty's Avatar
Car: 89 Trans am
an inch of hose thou? its not goign to change anything beside make it flexible.
i dont see the problem.
i want an actual reasonfor not doing it thou, not just because its not stock
Old Aug 7, 2005 | 08:02 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
you will never get it sealed right, and always have have a leak
Old Aug 7, 2005 | 08:54 PM
Borsty's Avatar
Car: 89 Trans am
cause the same method isnt used for fuel lines
Old Aug 7, 2005 | 09:39 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Ya know, there's a right way, and a wrong way. Your father told you the right way.
Do as you please, it's your car.
Myself, I'd rather not deal with swollen/shrunken hoses and leaks and twisting filler necks over the lifetime of my car, but you seem to have a better idea, so go for it.
amargari
Nov 10, 2015 02:09 PM
86IROC112
Nov 7, 2015 06:50 AM
ndndndnd
Sep 28, 2015 08:00 AM
reactor60
Sep 22, 2015 01:44 PM
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
