Oil Pressure problem
Old Aug 7, 2005 | 08:43 PM
BrianW124's Avatar
Car: 1989 RS Hot Cam 350
Engine: 350 Vortec heads, LT4 Hot
I am working on my buddy's Camaro that has a 350 TBI out of a Blazer. The motor has about 120,000 miles. When its cold its holding about 40 lbs of oil pressure. When it gets warm the pressure drops to about 10 lb. When I rev the motor the pressure will not raise (according to the needle) I have already changed the pressure sensor. The gauge was reading higher with the old sensor. IS THE PUMP going or do I have a electric problem.
Brian
Old Aug 8, 2005 | 04:58 AM
ede's Avatar
ede
try a mechanical gauge
Old Aug 8, 2005 | 06:19 AM
BrianW124's Avatar
Thanks Ede but can you think of a place other than on the back of the block UNDER the distributer to tap the oil pressure feed. I do not have the port just above the timing cover like the older blocks. I can't get to this one without pulling the dist. which I may just have to do.
THanks
BRian
Old Aug 8, 2005 | 07:21 AM
todd200's Avatar
Car: 87 IROC-Z
Engine: 350ci
There is a port above the oil filter.
89GTAOz
May 16, 2020 09:31 AM
db057
Aug 22, 2015 08:17 PM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
