HOW MUCH FOR A VALVE SEAL JOB!?!?!?!
Old Oct 7, 2001 | 04:29 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
A 92 RS V8 5 Speed is for sale for 3000 it needs a paint job and a valve seal job. How much would it cost to get those damn valve seals fixed!?!?!?!?!!?
Old Oct 7, 2001 | 04:52 PM
ede's Avatar
ede
best to call a shop in your area than ask here since labor rates vary, but i'd guess 4 hours flat rate and 25 dollars for parts.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Oct 7, 2001 | 04:54 PM
Damon's Avatar
$200 all up, all in.
Old Oct 7, 2001 | 05:54 PM
poncho9789's Avatar
It only cost me 120 for a complete valve job with three angles on the valves and new seals installed.
Old Oct 7, 2001 | 07:04 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
<font face="Verdana, Arial" size="2">Originally posted by poncho9789:
It only cost me 120 for a complete valve job with three angles on the valves and new seals installed.</font>
My guess is you brought the heads in.
Old Oct 8, 2001 | 10:45 AM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
When i had my T/A heads done they got me for $300. That included 3 new valves as well. I had new valve stem seals and all the valves properly seated (don't know the term), cleaned and all that jaz. I live in NJ so it cost me a lot more that it would out west.
Old Oct 8, 2001 | 09:06 PM
Jcpstrat's Avatar
On a 305 T/A the dealership wanted $540 to replace the valve stem seals. I ended up doing it myself but already had the TPI and intake manifold off to fix a bad oil leak. The cost of seals was less than $20 but it was a major pain to do and I don't know if I could have done it without that other stuff out of the way. Good luck.
Old Oct 8, 2001 | 09:48 PM
poncho9789's Avatar
<font face="Verdana, Arial" size="2">Originally posted by 8Mike9:
</font>
yea I had the heads off the car and a cheep but good machinest.
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
tgp1990
Sep 4, 2015 06:24 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
