RR or not to RR that is the question.
Old Oct 8, 2001 | 02:20 PM
BitchinCamaro's Avatar
I have the common smoke at start up so I am going to be replacing my seal. I was thinking as long as I am in there why don't I replace those tired springs. But I was also thinking adding some 1.6 roller rockers. My local speed shop quoted me $350 for them. (Crane gold, only ones that will fit under the valve covers) Do you guys think it is worth it? Can I reuse these if I change out the heads? Should I just go with roller tip stamped rockers? I don't know a lot about upgrading valve trains so any advice would be appreciated. Thanks.
-='89 Iroc-Z=-
-= 350 TPI =-
Old Oct 8, 2001 | 02:52 PM
Chevy Muscle's Avatar
<font face="Verdana, Arial" size="2">Originally posted by BitchinCamaro:
But I was also thinking adding some 1.6 roller rockers. My local speed shop quoted me $350 for them. (Crane gold, only ones that will fit under the valve covers</font>
Can't you just get some taller valve covers, that is, if you could get some cheaper RRs somewhere else?
1978 Y-88 TA (WS6, P6.6, T-Tops)
1993 Black 454SS
1989 Black IROC (TPI, T-Tops, LB9, 5-speed)
Old Oct 8, 2001 | 02:55 PM
rezinn's Avatar
Why not just get roller tipped rockers? They are much less expensive and will fit. Im not sure about how they will compare as far as performance, though.
Old Oct 9, 2001 | 12:20 AM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
I can tell you that those Crane Gold Series Race roller rockers will definately fit under the stock rocker covers without any modifications. They are also pretty damn noisey. I would say that if you don't plan on revving the motor really high, a roller tipped 1.6 rocker will give you good results and save you some cash - and noise.... hehe.
1987 GTA L98 MD8
355, TFS Heads, LT4 Hot Cam
My GTA
The Minnesota F-body Club
ZZ3Astro
Aug 13, 2019 12:57 AM
fbodyfreakls1
Oct 6, 2015 06:34 PM
corey8084
Sep 17, 2015 02:56 PM
Wylecoyote08
Sep 8, 2015 08:26 AM
Ian Irvine
Sep 4, 2015 08:08 AM
