what kinda tranny fluid should i use? also, tranny cooler
Old Oct 7, 2001 | 09:09 PM
breathment's Avatar
I was gonna put this in the tranny section, but i thought there is probably alot of yall who have opinions on this subject who don't usualy read that section.
Im going to change the filter and flush the fluid in a few days. and i want some good fluid to put in. Should i go with just the plain synthetic stuff that i can get at PepBoys, or what about the Trick Shift fluid? is it really worth getting, what are the pros and cons? Also, can anyone recomend a easy to install tranny fluid cooler? or at least one were i can find all necessary parts at autozone.
- David
88' GTA 5.7L TPI MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series
http://www.geocities.com/david_angel_16
Old Oct 8, 2001 | 07:19 AM
ede's Avatar
ede
i'd use synthetic unless i was after harder shifts and then i'd get a shift kit a nd use synthetic. amsoil makes some good synthetic products look up five7kid here and see what he sells.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Oct 8, 2001 | 09:30 PM
breathment's Avatar
how does the Trick Shift make it shift harder, and will it cause any increase in wear? And i already have a shift-kit.
- David
Old Oct 9, 2001 | 01:39 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Dextron has friction modifiers added to it, same stuff as the posi additive for rear ends. It helps the clutches and bands engage smoothly. Trick Shift is ATF without the friction modifiers. They've just come out with a synthetic version, I don't know anything more about it, though.
In general, synthetic base stock provides a broader temperature operating band (thinner when cold, thicker and more resistant to oxidation when hot) than petroleum base, and provides better lubrication for the parts that slide against each other (pump, bearings, bushings). I don't know what Pep Boys sells, but since the formulation will vary from manufacturer to manufacturer, I can't endorse those I haven't seen any data on. They all should meet the Dextron III requirements, but you can do that without a synthetic base, obviously. However, I don't think you could go wrong with AMSOIL or Mobil 1.
For a tranny cooler, most anything rated for 10,000 pounds would be adequate.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. 2-1/2" cat-back, ZZ3 intake, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 CC system w/'87 LB9 block, ZZ3 cam, ported World 305 heads, Hooker 2055 headers, 3" Catco cat & 3" catback, restalled TC, Spohn SFCs).
57 Bel Air, my 1st car. '66 396, 9.7 CR forged TRWs, Weiand Action+, Holley 750VS w/4150 conversion, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 600 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
HoosierinWA
Oct 7, 2015 10:15 AM
bjpotter
Oct 4, 2015 07:48 PM
FormulasOnly
Oct 2, 2015 05:52 PM
mfp189
Sep 27, 2015 09:25 AM
