9 years with out starting
Old Aug 10, 2005 | 07:58 PM
kaydoe's Avatar
Car: 92 T/A vert
Transmission: auto
Axle/Gears: 3:42
After 9 years I want to drive my gta again. My 88 GTA L98 auto has been sitting inside without being started. I know I will have to do a lot of work. Change all fluids and flush everthing.
drain the tank, new injectors. new batterey What else should i do?
Old Aug 10, 2005 | 08:17 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Check your rubber parts.... seals, hoses, etc. After sitting that long, they can dry out and crack.
Old Aug 10, 2005 | 08:22 PM
87350IROC's Avatar
Car: 87' IROC
you don't necessarily have change the injectors. I would replace all fluids, see how she runs and then go from there.
Old Aug 10, 2005 | 08:31 PM
brutalform's Avatar
[B]
Good advice here. Dont overlook the brake hoses either. 9 years is quite a while. Be safe.
Old Aug 10, 2005 | 08:34 PM
kaydoe's Avatar
Car: 92 T/A vert
Transmission: auto
Axle/Gears: 3:42
I guess I should pull the plugs and spray some wd40 in the cylinders. also if I get it running well enough the tires have to go
Old Aug 11, 2005 | 07:38 PM
Vader's Avatar
Injectors? No. Wait until it gets running.
A new fuel filter? Definitely. And drain all the fuel you can, then fill with the lowest octane gasoline you can get. The higher volatility and solvent power of the low octane may help dilute some of the leftover fuel. Be prepared to change teh fuel filter more than once.
Tires? Maybe. My '86 is still running on the original Eagle ZR50 tires in front at 49,000 miles. As long as they are not rotted, they might be O.K. to start out with.
Wait to flush the cooling system until the engine is running and warm.
Don't forget a new air filter, and inspect the intake tract for "visitors".
Good luck. We're here for you.
Old Aug 11, 2005 | 10:58 PM
plathegame's Avatar
Car: 1986 trans am ws6, 66 grandprix
Engine: 88 iroc 5.0 tpi
Transmission: 700 r4 built by rocky pirrone
Axle/Gears: 327
[QUOTE
/QUOTE]
good idea.. i had a amx that was sitting outside for 10 years so i sprayed liquid wrench in all the spark plug holes, turned the engine by hand a few times than cranked it a few times w/ the coil wire off.. it loosened up real good. after a new set of plugs & fresh gas it started right up.. the only thing besides the obvious oil and coolant change i had to do is rebuild the carb because the gas was all varnished inside it
Old Aug 12, 2005 | 05:32 PM
355gta's Avatar
Car: 1989 pontiac firebird trans am gta
Engine: 355
Axle/Gears: 327:1 9 bolt
When you get it started put it in neutral. Do not let it engage in reverse, go straight to neutral( do not pass go, do not colect 200 dollars....LOL). All the clutches are dry and if it engages in any gear it will burn them out. With it in neutral it will circulate the fluid and get the clutches back to normal. This is very important. You will not make it 10 miles.
Old Aug 12, 2005 | 05:44 PM
stope21's Avatar
why not just start it in neutral, or leave it in park?
Old Aug 12, 2005 | 08:00 PM
kaydoe's Avatar
Car: 92 T/A vert
Transmission: auto
Axle/Gears: 3:42
Wow I was just thinking about someway to pump trans fluid in the cooler to pre lube the tranny. That sounds easyer thanks for all of these tips
I will keep you guys posted on my progress.
Chris
Old Aug 12, 2005 | 08:34 PM
355gta's Avatar
Engine: 355
Park will not circulate the fluids as well as neutral will. I never concidered starting it in neutral. That would make more since.
Old Aug 17, 2005 | 09:40 AM
Epro's Avatar
Car: 95 Camaro Z28
Transmission: 4L60E w/ shift kit
Axle/Gears: 3.23s
What kind of fluids?
Like power steering fluid, brake fluid, oil, window washy?
Old Aug 17, 2005 | 09:43 PM
corky9491's Avatar
Car: 83 Berlinetta
Engine: 355
Transmission: TH350
I would bleed all the old brake fluid out, just like you would if replaced a caliper or rear wheel cylinder. The fluid after that long will be rusty and nasty.
Old Aug 17, 2005 | 10:46 PM
Air_Adam's Avatar
I think he means the trans fluids.
Frozer!!!
Jan 19, 2024 04:55 PM
jharrison5
Aug 19, 2015 05:53 PM
jbd1969
Aug 17, 2015 07:06 PM
cstrobel65
Aug 15, 2015 10:19 AM
Street Lethal
Aug 14, 2015 08:25 PM
