code 14 and 34. help
Old Aug 11, 2005 | 09:41 AM
smokin_iroc-z28's Avatar
Car: 1987 iroc z-28
Engine: 305 w/ holley 600
Hey guys, i just pulled the codes on my engine and i got a 14 and a 34. i really need help to determine what it is thats wrong. if you guys could help me that would be great.
Old Aug 11, 2005 | 10:18 AM
Car: 1987 iroc z-28
So can anyone help me out?
Old Aug 11, 2005 | 11:45 AM
HalfInchWrench's Avatar
Car: 85Z28 87GTA 91GTA 98SS
Engine: SBC, LS-x
Transmission: T-5, 700-R4, T-56
Did you look up what the codes mean? I believe 34 has something to do with the MAF or TPS but I am just going by memory. Don't make me pull out a shop manual and I or many others should be able to help you out. Provide as much info as possible and you will get much better help.
Old Aug 11, 2005 | 01:09 PM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
You'll need a scan tool do diagnose a code 14; ECM is receiving a high temp from the CTS,
is Scan tool temp >130°c (266 degrees F) for more than 3 seconds
if yes
then disconnect CTS harness 2 wire connector - yellow/black wires
Scan tool's temp should be less -30°C
If yes
then replace sensor
if no
then CTS yellow signal wire is shorted to engine ground,
else CTS yellow signal wire is shorted to CTS black wire which, is ECM signal ground.
Code 34 is MAF low air flow, possible leak between maf and throttle body, or maf signal shorted to ground.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
