350 HO Deluxe Possibility?
Old Aug 11, 2005 | 08:50 PM
crrllmich's Avatar
Car: 91 Camaro RS, 99 Camaro Z28
Engine: L03, LS1
Transmission: 700R4, T56
Axle/Gears: bunch of 10 bolts how scary is that
How much power should a 350 H.O. crate deluxe push with a Hot Cam and Fast burn Heads?
Is anyone running a simular setup?
Old Aug 11, 2005 | 10:09 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I believe that GM already makes a crate engine similar to that and they rate it at 385hp. They have a 425hp version of the crate motor as well. They are called "fast burn 385" and "fast burn 425" respectively. They both use the GM fast burn heads but I cannot remember off hand what cam they use.
Old Aug 11, 2005 | 11:09 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Correct, but why would you want to run fastburn heads on a 350. It makes no sense the ports are 210cc's to big for anything less than 383 for the street. The vortec heads on the HO will be better if you have them modded to run more lift.
Old Aug 12, 2005 | 08:24 AM
crrllmich's Avatar
Engine: L03, LS1
Shifty....well really I wanted to go the deluxe because of the less shopping I will have to do for all the parts I need to get her running... I want to customize my own engine and have the feeling that I gave it that power... I also may want to wait a while to have that much power....take steps your know. (I am not the only one who drives the car)
Leigh... Fastburn Heads go on 350s all the time... I actualy have them in my other car... Now for the lift... the engine comes with 1.5 rockers...if I moved to a 1.6 with the LT4 Hot Cam shouldn't I have plently of lift?
Old Aug 12, 2005 | 08:25 AM
crrllmich's Avatar
Engine: L03, LS1
Would the 650 CFM carb be an issue?
Old Aug 12, 2005 | 11:12 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
He is refering to the small guide clearance on stock vortec heads. A hot cam will be way past the safe zone in that regard. Vortecs seem to range from .460 to .480 lift.
Old Aug 12, 2005 | 11:39 AM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
http://www.sallee-chevrolet.com/Chev...eeZZ430HP.html
scroll down for specs
Old Aug 12, 2005 | 12:34 PM
crrllmich's Avatar
Engine: L03, LS1
HEH exactly what I am building.... has the hot cam and fast burn heads....went to 1.6 rockers I see...and 750CFM carb... I would be happy with those power ratings... Thanks for the link!
Am I missing anything else I need?
(besides fast burn heads, 1.6 rockers, 750 CFM carb, Hot Cam)
Old Aug 12, 2005 | 01:29 PM
Lo-tec's Avatar
a lot of $$ for gas!!
Old Aug 12, 2005 | 02:03 PM
crrllmich's Avatar
Engine: L03, LS1
LOL shouldn't be tooooooooo bad.... lol... its a weekend driver anyways...I am happy.
Infested
May 22, 2018 11:56 PM
camaro71633
Sep 1, 2015 10:24 AM
Keith5
Aug 27, 2015 04:37 PM
Eric-86sc
Aug 24, 2015 09:01 PM
86iroc z Z28
Aug 21, 2015 10:37 PM
