squeek noise driving me insane
Old Aug 13, 2005 | 02:39 PM
IEatRice4dinner's Avatar
Car: IROC-Z
Engine: L98 350/ 5.7L
not a 3rd gen but an 88 olds cutless sierra
(beeter car but still gm creation lol)
thing squeeks like crazy...
the faster i go the faster it goes
if i hit the brakes firmly the sound goes away
if i hit a bump or go up hill it stops but quickly returns.
it kinda sounds like the wear sensor thingy on the brakes but it dont sweek when u use the brakes.
it used to not do it if i turned left... now it does it all the time.
anyone know what it might be...?
Old Aug 13, 2005 | 04:47 PM
NastyL98_T/A's Avatar
Car: '88 T/A and '90 T/A
Engine: LB9/383
Transmission: T5/700R4
It's the wear sensor thingy.
Old Aug 15, 2005 | 04:11 AM
MikeDirntRulez's Avatar
Car: 1990 Camaro RS
Engine: 305 TBI (L03)
Transmission: 700R4 (MD8)
Axle/Gears: 2.73 Open (GU2)
Brake pads have had it, sho nuff'
Old Aug 15, 2005 | 09:35 PM
1meanGTA's Avatar
Car: 1987 GTA/1998 Explorer
Engine: 355, trick flow heads, zz409 cam, 3
Transmission: 700r4, shift kit, valve body
Axle/Gears: precision 3.73's, auburn diff
is your car any louder? loose bolts on the collectors can make the 2 pipes squeek rubbing against each other, but your car would be noticably louder
Old Aug 15, 2005 | 11:18 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
its the wear bar on the brakes
theshackle
Sep 17, 2020 08:26 AM
xxx3man`
Sep 23, 2015 10:37 PM
B_Dubya
Aug 26, 2015 05:09 PM
BlackBoulder
Aug 11, 2015 11:15 PM
