anyone with a 91-92Z 305 help
Old Aug 15, 2005 | 06:28 AM
1QUIKTA's Avatar
I am missing some sensors/relays on the drivers side firewall. I will include a pic of what I am talking about. I already tried the electronics section and not much help.
TIA,
Chris
cldetamore@zoominternet.net
Old Aug 15, 2005 | 07:44 PM
92blue's Avatar
Former Sponsor
Car: 1992 Camaro RS
Engine: Yet another 350 TPI
Transmission: Borg Warner 6 spd
Both of those plugs use the same relay. This is what it looks like...
Let me know if you need it, I have them new for $15 from GM.
Old Aug 15, 2005 | 07:50 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
I believe on the 90-92's, thats where the fan (2) and fuel pump relays go
Old Aug 16, 2005 | 12:38 AM
1QUIKTA's Avatar
92 blue, I may be getting with you on those fan relays. Do you have the fuel pump one also? There are 3 connectors there (can't see in pic). There is also one relay on the left side of the bracket (attached to the bracket) that is plugged in also (at least I think it is). I will hopefully get a better look Wednesday.
Old Aug 16, 2005 | 12:56 AM
Jade Grey's Avatar
Car: 1992 Pontiac GTA
Engine: 305TPI
Axle/Gears: 10-bolt, 2.73
8Mike9, is right (as usual) about the '90-'92 L98/LB9.
They are from left to right on the photo: the secondary cooling fan relay, the fuel pump relay, and the fan relay.
Edit: I had to clarify left/right.
pjsparts
Oct 29, 2025 06:39 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
rsrookie
Sep 5, 2015 07:08 PM
Formula_88AE
Sep 3, 2015 01:47 PM
