Whos running an Accel Superram?
Old Aug 13, 2005 | 02:50 PM
Fmandan's Avatar
Car: 1987 Formula 350
Engine: TPI 350
I'm wanting to know how happy people are with this intake?
Some Questions:
1. Can I run stock TPI ECM with a custom prom to achieve good power accross the board?
2. Do you have to run Accels computer set up with this intake?
3. Do all Superram upper intakes have a PROVISION for an EGR valve?
Thanks so much. --Dan
Old Aug 13, 2005 | 04:45 PM
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
1. Yes
2. No
3. The upper doesn't have the EGR, it's on the lower intake (base).
I had a Superram for years...Overall I liked it for a stout street car, I ran mid to low 12s with it. 2 things I hated about it was price and the PITA installation.
Do a search and you'll find some good tips on installing one.
Old Aug 13, 2005 | 04:52 PM
Fmandan's Avatar
Engine: TPI 350
Specificly what did you like about your holley stealthram better than your Accel superram?
Old Aug 13, 2005 | 07:05 PM
IROCZZ3's Avatar
Car: 87 Buick GN
Price and ease of installation!
Not to mention ease of maintenance. I can have the injectors off in 15 minutes.
Above all I was looking for more top end than the Superram (which I got). I wish the Stealtram would've came out back in 1997 when I first bought my Superram.
If you need to pass smog then the Superram is the best (and only) smog legal intake setup.
Old Aug 13, 2005 | 09:39 PM
Fmandan's Avatar
Engine: TPI 350
What would you say the RPM limits of the Accel superram intake are? I mean lets say I have a cam that would make peak power at 6000rpm with a carbed intake. With the Superram I'd be looking at a somewhat lower HP number at WHAT RPM?
Old Aug 13, 2005 | 11:37 PM
IROCZZ3's Avatar
Car: 87 Buick GN
It would be hard to say, but generally the superram's biggest advantage is making nice midrange torque throughout the powerband without much lowend torque loss.
If you need power past 6k rpms you can port the entire superram setup as others have done here or go to a short runner intake like the stealthram or miniram. A lot depends on engine size, cam, head flow and intended vehicle usage....
eightsixseven
Dec 16, 2024 01:50 PM
Infested
May 22, 2018 11:56 PM
tazs2000
Jul 15, 2017 08:44 AM
evilstuie
Feb 28, 2016 03:33 PM
marcusaw
Aug 10, 2015 08:13 AM
