305 VIN E base timing
Old Aug 14, 2005 | 09:54 AM
Chuck 2389's Avatar
Have a '89 Camaro RS with the basic , stock, 305 VIN E. Need to set ignition timing but all the manuals including the GM service manual say set timing per the underhood decal. Trouble is the decal is long gone. Anyone know the base timing ?
Old Aug 14, 2005 | 09:59 AM
Green92RS305's Avatar
Car: N/A
Engine: Gen I 408
Transmission: N/A
Axle/Gears: N/A
with the brown/white (i believe) connector disconnected base timing should be set to 0*. or for a slight performance gain you can set it anywhere from 2-8* and use premium gas.
Old Aug 14, 2005 | 10:27 AM
Damon's Avatar
And FYI, the timing tab can only be seen by looking straight down behind the water pump. Lotsa people have trouble locating it if they are doing this for the first time.
Old Aug 14, 2005 | 06:59 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
As stated above the base setting with the EST dissconnected is 0°. I would not run more than 4° advanvced. There really isn't any significant performance gain and you will more than likely have to run a higher octane fuel. A few degrees base will give you sligthly better throttle responce. Once of the advantages swirl port heads have is that they don't need and don't like a lot of initial base timing.
Old Aug 14, 2005 | 10:00 PM
Chuck 2389's Avatar
Thanks all for your advise and tips!!!!
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
Randomtask2
Aug 13, 2015 01:57 AM
