Want to run a LT-1 accessory bracket?
Old Aug 16, 2005 | 10:59 PM
gixxer92's Avatar
Car: 1986 IROC, 2017 Silverado
Engine: 7.0L, 6.2L
Transmission: Tremec Magnum, 8L80
Axle/Gears: 3:23, 3:55
I'm doing this to my 383 so I can do the supercharger since they are going fairly cheap or just have the room there for a turbo.
Don't know if this has ever been posted, I don't post much just thought I'd let everyone know that the LT-1 bracket, bolts to my L-98 motor if you ream out two of the bracket holes, depending on your gasket thickness (not sure, I had to ream mine)
Power Stering pump (rack -n- Pinion) isn't there yet but will be soon.
Also the stock alternator is too big unless your running center bolt valve covers to put the LT-1 valve covers on. I'm runnin Perimeter and have to either buy the MSD alternator that fits there and is smaller or have a set of aluminium valve covers notched and rewelded.
Regards,
Tony
Old Aug 21, 2005 | 06:28 AM
Vader's Avatar
Are you planning on an LT1-type P/S pump with remote reservoir? Have you considerd the electric power assisted steering units? I haven't heard of too much trouble with them yet.
Old Aug 21, 2005 | 09:54 AM
gixxer92's Avatar
Engine: 7.0L, 6.2L
Yes I was going to mount the remote reservoir, my plans were to go with with a rack and pinion on a new K member. After reading a post in the Chassis section of the use of a rack with the stock spindles, I'm kind of at a stop till some resolution comes out on what to do to keep the steering radius.
No I did hadn't read to much about the electric power assited, I will do a search for them and bone up a little, thanks for the info.
Old May 11, 2006 | 06:45 PM
gixxer92's Avatar
Engine: 7.0L, 6.2L
Updated the pics with valve cover now modified, baby steps
midge54
Dec 27, 2019 04:14 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
Fast355
Dec 2, 2016 06:33 PM
cRoe4
Aug 7, 2015 08:46 PM
