Trick Flow Heads Keith Dorton Intake Gaskets HELP
Old Aug 17, 2005 | 05:43 PM
roughskinjrz's Avatar
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
hey i looked on this site but diff people use diff gaskets i dont know which one to choose.
the person i purchased these heads from said they intake was matched to a fel pro 1205, i got that down. is there a kit i can buy with all these gaskets, or do i choose every gasket seperately it looks like it can get expensive.
i am running a 350 bored .30 over
all the gaskets i need would be:
trick flow g2 wedge aluminum head gaskets
trick flow g2 wedge aluminum headER gaskets
edelbrock elite aluminum tall valve cover gaskets
keith dorton signature series carburetor gasket (edelbrock 750cfm), i will be on a spacer to, so ill need 2.
i already know the gaskets for the keith dorton signature series are a fel pro 1205 which includes the distributor gasket.
if you can help as to which ones to exactly buy maybe i can get these purchased so i can get my motor together, please help.
Old Aug 17, 2005 | 09:25 PM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
ok i found out about the heads, would fel-pro 1010 gaskets be fine for the heads?
and what could i use for the header gaskets just standard? i found one fel-pro 1405, will this do fine?
Old Aug 18, 2005 | 05:08 PM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
noone?
Old Aug 18, 2005 | 05:12 PM
Rogue86's Avatar
Car: 94 Camaro
Engine: 380 sbc
Transmission: th400
Axle/Gears: 9" 4.11
Best bet is to find your heads on summit racing's web site, then under suggested parts, it should list your gaskets.
I don't understand why you are worked up over a carb gasket, go to the local auto parts store and buy one. Same with the valve cover gaskets... and most likely header gaskets
Old Aug 18, 2005 | 05:36 PM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
not really those, but i dont wanna buy head gaskets, then they blow and i have to get new ones and tear apart the motor again.
Frozer!!!
Jan 19, 2024 04:55 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
Mickeyruder
Sep 2, 2015 02:45 PM
Dialed_In
Aug 20, 2015 01:45 PM
