roller rocker question
Old Aug 18, 2005 | 01:44 PM
my1st88camaro's Avatar
Car: 88 Z28 Camaro
Engine: 355 TBI soon to be carb.
Transmission: 700R4 upgraded
Axle/Gears: 4.11 gears
i have valve covers that bolt on in the center. i want to put 1.6 roller rockers on my valvetrain but i'm not sure if they will get in the way of the center bolts are not? anyone know for sure?
Old Aug 18, 2005 | 02:37 PM
Diehardgm's Avatar
Car: 1994 z28
Transmission: A4
They should fit with the exception that you will have to take all of the sheet metal baffles out of your valve covers.
Old Aug 19, 2005 | 01:14 AM
Tony89's Avatar
Car: 1989 IROC-Z Convertible
Transmission: Art Carr 700-R4
several choices available
One can trim out the oil baffles, or choose one of the several aftermarket sets of roller rockers that are designed for centerbolt valve covers. You should always check clearances in any case, however.
Mickeyruder
Sep 2, 2015 02:45 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
LT1Formula
Aug 20, 2015 09:36 PM
Dialed_In
Aug 20, 2015 01:45 PM
IrocZ'85
Aug 17, 2015 06:24 PM
