basic timing chain set questions
Old Aug 19, 2005 | 04:30 PM
llvll4l2c91350's Avatar
yes ive searched and know this is a fairly common topic but am still somewhat confused as to which set to buy. basically i have 350 motor on a stand that im working on. not messing with the bottom end at all. just workin the heads, changing seals, gaskets, etc. so im lookin for something as good or lil better than stock. i understand its best to go with cloyes double roller chains. but which one exactly? will it be a set that comes with sprockets too? if i need to change sprockets, how do i install 'em? (guessing a regular puller will take 'em off? the motor was running smooth with no problems before i pulled it out. the old chain does have some slack.
TIA
Old Aug 19, 2005 | 04:36 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Timing sets come with the chain and sprockets (otherwise you're not buying a timing set, you're buying a timing chain.
The cam sprocket is held on by the cam bolts, the crank sprocket is pressed on. A gear puller will get it off, and you can buy, rent, improvise or steal an installation tool.
Old Aug 19, 2005 | 05:17 PM
thanks. which set would be best to buy. should i go to a parts store and just buy one or is there anything better i can have from summit or jegs? oil pump ive decided on already just need to know what timing set before i start ordering parts.
i was lookin at this one from the jegs page:
http://www.jegs.com/cgi-bin/ncommerce3/ProductDisplay?prrfnbr=137082&prmenbr=361
part # 220-9-1145
Old Aug 19, 2005 | 06:33 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
That should be just fine.
Old Aug 20, 2005 | 08:08 AM
just read on the summit site that this chain is a double. i read that in order to make a double fit the block has to be grinded or the chain will rub. is this true? i just want something i can slap on and go. im not going crazy with this block. pretty much just having it as back up in case somethin happens to my current 350 TPI.
Old Aug 20, 2005 | 11:11 AM
gonna just go with a single roller chain. part # 12371043.
Old Aug 20, 2005 | 12:02 PM
firebird45331's Avatar
Car: 86 Firebird, 2002 Monte Carlo, 91 v
I didn't have to modify my block for a double roller chain
Old Aug 20, 2005 | 12:14 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Just because it's a double roller doesn't automatically mean it's going to rub.
Old Aug 20, 2005 | 02:58 PM
what u guys think of that single roller setup? im thinkin double roller is a bit overkill for a basically all stock engine.
Old Aug 20, 2005 | 05:02 PM
I believe in overkill at all times for everything worth doing.
Old Aug 20, 2005 | 05:09 PM
NastyL98_T/A's Avatar
Car: '88 T/A and '90 T/A
Engine: LB9/383
Transmission: T5/700R4
The double will keep your timing more consistent, and I've never had to clearance a block for one.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
jharrison5
Aug 19, 2015 05:53 PM
MY87LT
Aug 17, 2015 08:43 AM
redmaroz
Aug 16, 2015 11:40 PM
