Heated O2s ever need replacing?
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Heres a question: Heated narrowband O2s ever need replacing?
Have a vehicle that seems to use two very expensive narrow band O2s. Ive taken other heated O2s out after 100k and they are very clean internally. No deposits at all. To me it seems as long as its not poisoned by any contaminates like antifreeze or silicone they should be good indefinatly. True or false?
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
False. Combustion is not a clean process. How long they will last will depend on may factors includin how clean the engine runs, how well the shield is designed and how sensitive the elements are. I've seen people running some into the 150K range... though I doubt I'd push it that far myself.
As a side example... the Gen III SHOs have a 100,000 mi replacement interval... I've yet to meet anyone that happily made it to 75K. The recommendation floating out there IIRC id 50-60K for those cars. I did mine at 40K. :shrug:
Car: 88 Camaro SC
Engine: SFI'd 350
One of the engines with 120k I took one out of was running like puke. Still ran like puke after the new O2 but the old unit (actual zirconia coated ceramic probe) was spotlessly clean. The heating element seems to do a good job of driving all the garbage off. Although thats not to say that there arnt certain things that will still survive the heat treatment and cling to the surface.
Car: 88 Camaro SC
Engine: SFI'd 350
Its funny how expensive these heated NBs are. Almost as much as the freakin WB. Im giving the fnord some lovin by doing a major tune-up and its gonna cost like 120 for the botch units.
My OBD-II Ford didn't cost that much for o2 sensors.
i agree with Red Devil. The heated part has a few goals. It helps lower emissions by allowing the o2 sensor to get up to operating temperature quicker, to allow them to start to provide feedback quicker. They also had a purpose to help prevent the o2 sensor from going back to "sleep" during idle conditions where the exhaust volume would be less, thus, it was common for non-heated o2 sensors to "sleep" during idle, causing the system to go back to open loop mode.
Car: 88 Camaro SC
Engine: SFI'd 350
One of the really nice side effects of the heating is that it seems to keep the O2 very clean. With my non-heated one, all the soot and crap in the exhaust settle out onto the sensor, which is probably the main reason the old O2s have to be replaced so much.
Bosch does have different replacement intervals for the different types of o2 sensors in use (heated,non-heated,OBD-II generation).
Not sure if you have access, but can you see the o2 sensors "switching" fairly rapidly? As o2 sensors age, their response time decreases. Normally, the o2 sensor should be reporting rapid "switching" back and forth in regard to mixture.
Bosch recommends replacing unheated one- or two-wire O2 sensors on 1976 through early 1990s applications every 30,000 to 50,000 miles. Heated three and four-wire O2 sensors on mid-1980s through mid-1990s applications should be changed every 60,000 miles. And on 1996 and newer OBD II-equipped vehicles, the recommended replacement interval is 100,000 miles.
Car: 88 Camaro SC
Engine: SFI'd 350
I cant scan this car unfortunatly... Wouldve provided a conclusive yes or no as to whether they neede to be replaced. I just went ahead and replaced them anyway.
kyle5647
Aug 15, 2015 11:56 PM
