carb spacers
carb spacers
anybody ever install a carb spacer onto their camaro? i've got a 4bbl and was wondering if it actually did deliver more power/gas mileage as they advertise. what's involved in the installation? is it really involved?
I have one waiting for my 350, so I can't tell you how about the power/gas milage, but I have seen them installed. Basically, you put it in there and rebolt down your carb on top of it, simple as that really...not involved.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
It's a tuning aid. Not a fix. Carb spacers can be 4 hole or open. As short as 1/2" and as tall as 2". They can be made out of wood, plastic or aluminum.
Because each engine and car are different, you need to try different spacers or combination of spacer to find out what works best.
The gas milage increase would be very hard to detect. As for more power, they won't acutally give you enough to feel but you may see an extra couple of hp on a dyno. What they really do is move the power that's available into a different rpm range. Like I first said. They're a tuning aid.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block (times are for the current engine)
Best ET on a time slip: 11.447 altitude corrected to 10.99
Best MPH on a time slip: 119.42 altitude corrected to 124.86
Altitude corrected rear wheel HP: 493
Best 60 foot: 1.586
Racing at 3500 feet elevation with a typical race day over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Best 60 foot: 1.586
