will this work to see which injector is screwed?
Old Oct 14, 2001 | 08:51 PM
breathment's Avatar
My fuel pressure likes to rapidly fluctuate about 3 PSI +- 44. im thinking its one of the injectors staying open for to long or something, so can i hook up the fuel pressure guage, and then unhook each injector plug harness thing one by one untill the pressure smooths out? and then go from there??
- David
88' GTA 5.7L TPI MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series
http://www.geocities.com/david_angel_16
Old Oct 14, 2001 | 11:52 PM
Vader's Avatar
Breathe,
You can't hurt anything by unplugging the injector electrical connectors, so that is a viable test procedure. You may get lucky and find a sticking injector, but you may also discover that the problem is elsewhere. At least you can eliminate the injectors by your test.
Later,
Vader
If you want to beat the World, it might reach up and pull you down...
Adobe Acrobat Reader
Old Oct 15, 2001 | 03:20 PM
TPI Guy's Avatar
Car: 1968 Camaro
Engine: 406
Transmission: Tremec TKO
You could buy a digital volt meter and see if the injector are getting the signal to fire
Old Oct 15, 2001 | 05:25 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I might add, if you disconnect the injectors one at a time, each of them should also affect the idle quality about the same amount. If one or more of them seem to have noticeably less effect than others on how the engine runs, then you need to get in touch with www.cruzinperformance.com
ICON Motorsports
1992rs/ss
Jan 31, 2025 05:10 PM
italiano67
Dec 11, 2016 09:21 AM
justin57
Aug 20, 2015 07:05 PM
TheJoeY88
Aug 13, 2015 06:51 PM
blacksunshine'91
Interior Parts Wanted
Aug 10, 2015 12:04 AM
