Help, help, help! Removed airbag from car, and car will not start???
Old Nov 7, 2000 | 09:37 PM
GOFASTER's Avatar
Car: 1991 Super Sport
Engine: 388 ci
Transmission: TH-700R4, 3500 Stall
I cut the yellow wire going to the airbag and removed the steering wheel, now the car wil not stay running? If I aply gas, it will stay running, but as soon as I let off the gas, she dies out, real quick, just no RPM's? Did removing the bag do something to the computer?
HELP!
25th Anniversary Z28
Old Nov 7, 2000 | 09:51 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
So let me get this straight...your car was running perfect and you removed the airbag and now it won't run, right??
I've seen people remove airbags before and just put a regular wheel on with no problems.
Never heard of one not starting/running.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
GO #3
Old Nov 7, 2000 | 09:54 PM
GOFASTER's Avatar
Engine: 388 ci
That is also what I thought? But, she was running great, then I cut the wires to remove the airbag, then nothing? She just won't stay idle, unless I give it gas, it will stay running, but as soon as I let off the gas, it dies??????
WTF????????
What else could it be? Runs good when I give it gas....
Old Nov 7, 2000 | 10:15 PM
GOFASTER's Avatar
Engine: 388 ci
Also, she smells like she is running rich?
What could it be?
Old Nov 7, 2000 | 11:03 PM
RSpeed's Avatar
Car: 92 Z, 91 Formula, 04 CTS, 01 Tahoe
Engine: 355 forged 4 bolt, SuperRam, 58mm t
Transmission: T5, looking for t-56
All I can think of is for you to try and connect the wires back together and see what happens.You may have accidentally unplugged something while you were under there and didn't realize it. Other than that,all I can say is WTF?!?!?!?!??
Old Nov 8, 2000 | 05:53 PM
RSpeed's Avatar
Check your e-mail if you already haven't. Oh,did you cut across both wires at the same time without pulling the fuse out first?
Old Oct 15, 2001 | 05:11 PM
Tom Batts's Avatar
"Check your e-mail if you already haven't. Oh,did you cut across both wires at the same time without pulling the fuse out first?"
if he did... what did he blow???
Old Oct 16, 2001 | 12:46 AM
86BIRD-MY FIRST CAR's Avatar
I guess your SOL buddy....
86 firebird 2.8
K&N replacement filter
modified air box
MSD ignitor
Old Oct 16, 2001 | 12:26 PM
TPI Guy's Avatar
Car: 1968 Camaro
Engine: 406
Transmission: Tremec TKO
Does it set a check engine code. On your way to cutting out the air bag you may have cut through the pass key or VATS system. This system reqiures a certain resistance in line from the computer to the ignition switch to allow cranking and firing. That means it requires a reference voltage, and if you cut the wire, your car won't start. Check that
355 c.i.
Dart 180 Heads
Lunati 224/224 cam
Harland Sharp 1.5 rockers
Performer RPM Manifold
Holley 600 cfm double pumper
Hooker Super Competition Headers
Flowmaster Exhaust
Competition Engineering Sub-frame connectors
Super T-10
GM posi 3.42 rear
Hurst Roll Control
13.9@102
Old Oct 16, 2001 | 06:26 PM
89Irocz23's Avatar
ya but he did say it did start, but runs bad
TheExaminer
Aug 26, 2015 04:59 PM
Linson
Aug 21, 2015 02:12 PM
drathaar907
Aug 10, 2015 07:44 AM
3rdgenparts
Aug 8, 2015 07:09 PM
