1985 Z car or lawn mower?
Old Oct 9, 2001 | 01:51 PM
Jaspyr's Avatar
I finally got the car to the point where it'll start and move. but hte thing sound like a lawnmower, you have to rev the thing for 5 mins or so before it'll idle, no air pump or ac. it wants to die evertime you put it in gear. the last owner relly messed things up. any ideas???
Old Oct 9, 2001 | 01:54 PM
Jaspyr's Avatar
ohh i shoulda specifyed, it's the 305 non-fuel injected
Old Oct 9, 2001 | 01:58 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Check for vacuum leaks.
"Rice burners are like tampons...Every pu$$y has to have one"
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
3" Hooker CatBack w/Aero Chamber muffler
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat, just switched to 180* b/c of winter coming and going to college in the mts.
3:73 Posi
Rebuilt 700R4
B&M Megashifter, 5" Autometer Tach w/shift lite
five7kid's Avatar
Transmission: 4L80E/4L80E
Start from scratch:
Does the SES light come on?
Check all plugs, wires, vacuum hoses, distributor cap, rotor, choke, anything connected to vacuum hoses, etc. He may have messed up the idle circuits or other carb internals, left control connectors disconnected, etc.
If all this fails, consider putting a blade and rear bag on it...
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. 2-1/2" cat-back, ZZ3 intake, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 CC system w/'87 LB9 block, ZZ3 cam, ported World 305 heads, Hooker 2055 headers, 3" Catco cat & 3" catback, restalled TC, Spohn SFCs).
57 Bel Air, my 1st car. '66 396, 9.7 CR forged TRWs, Weiand Action+, Holley 750VS w/4150 conversion, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 600 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
Old Oct 9, 2001 | 02:09 PM
Jaspyr's Avatar
well as of this moment NONE of the interior ligts work. i dun think he messes with the carb...i got it after a botched timing chain change
Old Oct 9, 2001 | 02:21 PM
Jaspyr's Avatar
actually come to think of it the SES light is the only thing that lights up inside, there are a few loose connectors, and there doesn't seem to be a wire going to the choke
Old Oct 9, 2001 | 09:12 PM
82camaro's Avatar
Car: 82 camaro SC
If you don't know how old the ignition parts are, I would put in new plugs wires cap and rotor to start with. Then check the spark...if you get a nice snap or it makes you jump when you grab it start on the fuel side. Make sure the choke is functional. See if fuel is dumping into the engine when its running or not(stuck float is what I'm thinking here) Oh, and let us know what each plug looks like--sometimes they tell a story. Also, what does the exhaust look like? What does the oil smell like? Is the oil full, overfull, not on the stick? Do you have good gas in the car?(not old)
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, currant red metallic paint. Lots of other stuff...
82camaro
Old Oct 10, 2001 | 12:48 PM
Jaspyr's Avatar
haven't pulled the plugs yet, it has a fresh oil change so it's full, i did however find that teh ecm fuse is blown along with a few others.
Old Oct 11, 2001 | 05:09 PM
Jaspyr's Avatar
okee a bit more messing around with it, I tryed to check the codes but, the check engine light stayed solid..no flashes at all
any ideas???
Old Oct 11, 2001 | 08:27 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
If you can even pull a code it seems to be in the "limp home" mode.
Old Oct 11, 2001 | 10:50 PM
wm_sorg's Avatar
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
If the car has been sitting a while pull the cap and check for excessive corrosion on the contact surfaces. There could be arcing and some other thisngs going on.
Old Oct 17, 2001 | 02:08 PM
Jaspyr's Avatar
okee it runs great, no vac leaks, WILL NOT IDLE, still no codes from the computer even with an actual gm code reader, oh and i just found the parking lights don't work eather
fuses apper fine tho
Old Oct 17, 2001 | 02:31 PM
CamaroX84's Avatar
Does it idle okay after it's warmed up? If so, I would say somethin with the choke.
Old Oct 17, 2001 | 03:14 PM
Jaspyr's Avatar
Not really it does do a bit better tho, i dunno but i think my ecm is dead, oh also how clogged does the cat need to be to stop my car from idling..i think it may be clogged
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
Reddeath210
Oct 6, 2015 08:20 AM
drathaar907
Aug 10, 2015 07:44 AM
Fronzizzle
Aug 9, 2015 01:15 PM
drathaar907
Aug 6, 2015 04:20 PM
