Need new fuel line
Old Oct 18, 2001 | 03:40 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Need new fuel line
I've got an 82 Camaro SC that was originally an LQ8, but now has a 350. It still has the original single 1/4" fuel line which isn't going to be adequate. What has to be done to replace it with a larger size?
Old Oct 18, 2001 | 09:55 AM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
Most practical thing to do would be to get a set of fuel lines from a car in the wrecking yard.Probably need everything from the tank pickup tube to motor.
More elegant fix (more expensive) would be to convert to AN fittings at the tank and use braided stainless steel hose.
I would avoid using a length of rubber hose as much as possible.
I would guess lines from a wrecked Z28 would
bolt right in, though I haven't had to do this to my car.Just go check out a car at the wrecking yard that's got bigger lines.
-Rich-
Old Oct 18, 2001 | 02:20 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Get a 25' roll of 3/8" aluminum tubing from Summit. I don't know what pickup the LQ8 had, but if it's also 1/4", you'll want to replace that. Running the Al line is a breeze, as it bends easily without collapsing and flares nicely as well.
I'm surprised it only has 1/4" line - are you sure it isn't 5/16"? Even my lowly 2.8 had 3/8" line.
Are you sure you want to chop that car up? With less than 1k made, it's sure to be a collector's item...
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. 2-1/2" cat-back, ZZ3 intake, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 CC system w/'87 LB9 block, ZZ3 cam, ported World 305 heads, Hooker 2055 headers, 3" Catco cat & 3" catback, restalled TC, Spohn SFCs).
57 Bel Air, my 1st car. '66 396, 9.7 CR forged TRWs, Weiand Action+, Holley 750VS w/4150 conversion, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 600 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
Old Oct 18, 2001 | 04:36 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Yeah, it's 1/4" not 5/16", a -4 tube sleeve fits and a -5 doesn't.
As for keeping it stock, the car's already been modified, and even if there were less than 1000 made, I think the whopping 90 HP would negate any collectibility.
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
