internal or external?
Old Oct 18, 2001 | 07:06 PM
highhat's Avatar
I have a 1989 5.7 TPI
Is it internaly balanced or externaly?
Blue 1989 IROC Z28
Old Oct 18, 2001 | 08:05 PM
JETHROIROC's Avatar
You need an internal balance torsional damper. However, your 350 is technically not internally balanced thus the weight on the flexplate. I know it sounds confusing, just remember to go internal balance with the damper (if that's why you're asking). Hope this helps.
1990 IROC 350
Mods: Too busy trying to make it run right to mod it.
Airfoil, Dynomax cat-back, MSD coil, 180 t-stat, Bald Eagle tires,
Hypertech fan switch, Accel 23# injectors, Holley module, ported plenum,
Ported Daytona Yellow stock base, Moroso valve covers, other stuff,
Streetdampr, Ruger P95DC, hot wife, new oil filter, !cats, !TBC, !AIR.
18.0 @ 85MPH since I'm one big-a$$ MF
"It's better to have and not need than to need and not have."
Old Oct 19, 2001 | 08:39 AM
highhat's Avatar
Thats exactly why i'm asking. So if its externaly balanced why go with a dampener for internaly balanced????? i'm confused!
Blue 1989 IROC Z28
Old Oct 19, 2001 | 08:57 AM
ede's Avatar
ede
all SBC except the 400 are internally balanced. when GM went to the one piece crank seal they had to remove the flywheel flange, thought it wasn't a weight it did add mass to the crank, so that had to replace this mass with the butterfly weight on the flex plate/flywheel to maintain the correct balance.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Oct 19, 2001 | 09:38 AM
highhat's Avatar
Thanx guys !
Blue 1989 IROC Z28
morrow
Members Camaros
196
Jan 13, 2024 12:21 PM
mfp189
Sep 27, 2015 09:25 AM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
WickedBowtie
Sep 11, 2015 11:24 PM
scottmoyer
Sep 7, 2015 07:06 PM
