Can't get car to start
Old Oct 19, 2001 | 01:54 PM
Justin Moore's Avatar
Car: 1986 Z28
Hey fellas, I can't seem to get my car to start. Here's what happened. I recently went on vacation. The car was running decent before this. When I get back from vacation the car won't start. First thing I did when it wouldn't start was pull the plugs. They all smelled like gas like the engine was flooded. I then checked for spark. There was barely any spark, it was really weak (now I am not sure how much spark plugs are supposed to spark but the spark seemed really weak). So I replaced cap and rotor, wires, and coil with Accell and MSD stuff. This also did not get the car going. I then changed the plugs because they are cheap and I wanted to rule that out. But still the car doesn't want to start. I am not sure what else it could be is there anything else I should be checking??
Also the car is an 87 IROC with at 5.7L TPI engine.
Old Oct 19, 2001 | 02:08 PM
Undrtkr25's Avatar
Does the battery have a good charge? Is the car turning like it has a good charge or is it slowly turning?
'89 Chevy Camaro
305 TBI
COMPLETELY stock
Old Oct 19, 2001 | 02:22 PM
Car: 1986 Z28
I just put a brand new battery in it last night and it is turning over fine. I was just talking with someone and they suggested to replace a module which is located under the distributer cap. What is this module and what does it do??
Old Oct 19, 2001 | 03:15 PM
88firebird305's Avatar
Hey the ignition module got me to, was driving and it just died. Not sure what it does but i replaced it in like 5 mins and every thing was fine started right up. That would be my next move.
Just found this
Function: The ignition module fires the spark plugs with signals from the ECU. Older modules were restricted to just this task but many modern modules perform a variety of tasks, including timing, dwell and current control
[This message has been edited by 88firebird305 (edited October 19, 2001).]
Old Oct 19, 2001 | 03:37 PM
Car: 1986 Z28
Thanks, I was just reading about them myself and it seems like the next logical step. What brand would you suggest??
Old Oct 19, 2001 | 03:58 PM
I just got the stock one from gm. My aftermarket igination system i think bypasses that module? Been sitting on the shelf wiating to be put in, I heard mixed things about after market ones, getting to hot burning out? Just remember to put a go coatting of silcone grease under it to help heat transfer.
Old Oct 19, 2001 | 04:28 PM
ede's Avatar
ede
best way to tell if your spark is strong enough is with a spark tester. if it makes spark with the tester you have another problem, if not i'd look at the moduel. since you mentioned wet plugs after the spark test i'd look at the FPR or a leaking injector.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Oct 19, 2001 | 05:15 PM
Car: 1986 Z28
OK. I took the dist cap off and found that the wires going to the ignition module were off and the connector was broken. I don't know which way to put them back on. There is a yellow and a green wire and on the module iteself is the letters P and N next to each connector. Does anyone know which wire goes where??
Wade787b
Sep 29, 2015 01:15 PM
TheExaminer
Aug 26, 2015 04:59 PM
86Base
Aug 8, 2015 01:34 PM
L98GTA87
Aug 5, 2015 11:02 PM
