WIRING QUESTION - Ok, I was a dummy!
Old Oct 17, 2001 | 05:52 PM
Tom Batts's Avatar
del
Old Oct 17, 2001 | 08:36 PM
Guest
Guest
Posts: n/a
Code alarm? Like a car alarm of some sort? I'd imagine someone may have put a kill switch in there somewhere like in the fuel pump or ignition wire thats causing the problem. I dont think you blew any electronics anywhere.
Old Oct 18, 2001 | 07:06 AM
Tom Batts's Avatar
del
Old Oct 19, 2001 | 03:48 PM
Tom Batts's Avatar
del
Old Oct 19, 2001 | 05:57 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
most likely the alarm has an ignition kill, see if you are getting 12v on the red wire to the coil, with the key in the on position if not you have to trace it back to the ignition switch to see where it is tied in to the kill switch, but anyhow you said it wouldnt start after the alarm went off? dont you have a remote to disarm it?
Cleotiz
Jan 6, 2018 08:56 PM
Caspar
Jun 19, 2016 11:19 PM
Bryan F
Aug 18, 2015 02:28 PM
86IROC112
Aug 17, 2015 07:57 PM
redmaroz
Aug 16, 2015 11:40 PM
