a NEW problem with my GTA....
Old Oct 19, 2001 | 05:17 PM
Dave M's Avatar
I posted this on the Tranny board but didn't get much response, so I'm trying here....
I finally got my GTA back on the road after a year-long hiatus, during which I drained the tranny fluid and replaced the filter, among other things. I initially refilled the tranny with B+M tranny fluid. A friend warned me not to use it because he said it made his 700R4 in his IROC act funny. I used it anyway, and sure enough the tranny wasn't shifting at the right points and didn't want to transfer the torque to the wheels. I quickly drained that fluid and relaced it with good old Dexron/Mercon III fluid, filling it to about a quart shy of where it was supposed to be. I then took it out for a quick test drive to make sure that's what the problem was, and the car ran beautifully, no prblems whatsoever.
This morning I got the car out again to take for a spin and now I've got a problem. It seems to shift first to second fine, but it wont shift to 3rd. It seems to let go of 2nd like it wants to shift, but never grabs 3rd, it's just like it's in neutral. It has reverse, and if I keep in 1 or 2, it's fine, but if I put it in D or OD it'll go through first and second but just rev freely when it lets go of 2nd to get 3rd. I added the missing quart of tranny fluid that I left out, but that didn't help. The car only has about 30 miles on it since I got it running again from being down all year (bad ecm). I ran it about 25 miles with the B+M fluid in it and about 5 miles with the other fluid in it a quart low while it ran great.
Anyone have any idea where the problem could lie? The tranny was rebuilt with a level 10 rebuid kit and a transgo shift kit about 2-3 years ago, which wasn't more than 15,000 miles ago. The tranny absolutely kicked *** before the car was down last year, and seemed fine yesterday when the I refilled with the Dexron/Mercon fluid. What gives?
(The car is an 88 GTA, L98, 700R4)
Dave M
88 GTA
Old Oct 19, 2001 | 07:59 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I would try reposting on the tranny board. Try to get the attention of transfixleo or Probuilt, they know their stuff. You could even try emailing them. I have noticed that transfixleo posts mostly in the early morning around 7am I believe Mon-Fri., if that helps at all.
"Rice burners are like tampons...Every pu$$y has to have one"
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
3" Hooker CatBack w/Aero Chamber muffler
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat, just switched to 180* b/c of winter coming and going to college in the mts.
3:73 Posi
Rebuilt 700R4
B&M Megashifter, 5" Autometer Tach w/shift lite
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
