timing problem
Old Aug 29, 2005 | 02:01 PM
ejm's Avatar
ejm
Car: 83 Black T- top Firebird
Engine: Carbed 350
Transmission: 5 speed
timing problem
Hey I just swapped a carbed 350 into my Firebird and it was running pretty well. I checked the timing and it was like 40* before tdc(I am guessing becasue it was probally at 10:00 and the 0* mark is at about 2:00. I put it to 0* and idle sounded better but it sputters as it revs up.
The timing tab and balacer came with the engine so I know they are correct.
I am wondering if this 0* would casue this and it needs to be tuned or what are the symptoms of being to far advaced or to retarted. If I know the symptoms I could figure out if maybe the ring slipped.
Old Aug 29, 2005 | 04:53 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Is the carburation/ignition stock, or has it been replaced with old-school mechanical carb & distributor?
Was anything disconnected when the timing was checked?
Old Aug 29, 2005 | 05:56 PM
ejm's Avatar
ejm
Engine: Carbed 350
It is vacum advance distrubutor. I played around with it and it seems to be running well again.
I moved the vacum hose to a different port on the carb(which is a holley 600). Then I set base timing (with vacum disconnected)to 2* or 4*
I am going to let the engine cool down and make sure everything is still good. How much base timing should I set and what way makes it easier started, advancing or retarding?
Old Aug 29, 2005 | 06:41 PM
five7kid's Avatar
8-12 is pretty typical for a vacuum/mechanical advance system, with the vacuum disconnected for the adjustment.
Ghettobird52
Jul 5, 2024 11:18 PM
Infested
May 22, 2018 11:56 PM
Fronzizzle
Aug 17, 2015 02:52 PM
