RADIATOR FLUID LEAKING!!!.....please help!
Old Oct 20, 2001 | 11:06 PM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
Transmission: TH-700R4
Axle/Gears: GM Axles and GM 3.73
my car was leaking radiator fluid and i saw some up by the thermostat and so i got a new gasket.....well i think that helped cuz the old gasket looked like a piece of paper!!!.....but its still leaking
i got up under the car and i think its the lower radiator hose....but im not sure.....i thought i saw some on my water pump....what could this mean??
if i had to how hard would it b to replace the water pump??
84TA T-tops L-69 305HO TH-700R4 stock 190hp and 240 ft-lbs.
new best E.T. (dont laugh) 15.986 @84.93mph
old best E.T 15.997@86.04
http://www.geocities.com/K_towngangsta
Mods-
K&N Air filter
Old Oct 20, 2001 | 11:25 PM
zslug's Avatar
Matt, I'd suggest you take it to a shop and have them pressure test the cooling system; that'll usually locate the leak.
Otherwise, any coolant that leaks out gets blown around by the fan when you're running, and flows downhill when you're not- so where you see the coolant may be nowhere near the leak!
Zslug
May the road rise to meet your treads...
'84Z, 5sp, stock 305, Edelbrock intake, GTA wheels
[This message has been edited by zslug (edited October 20, 2001).]
Old Oct 20, 2001 | 11:26 PM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
how much does it cost for them to do that?
Mods-
K&N Air filter
Old Oct 20, 2001 | 11:35 PM
zslug's Avatar
Depends on whom you're dealing with... if there's a garage you've been doing business with, they'll probably do it for nothing. I can't imagine anyone charging more than 10 bucks or so- it's just a small manual pump that attaches in place of the radiator cap, a few strokes of the pump brings the system up to pressure, and then it's just look for the antifreeze to find the leak.
Zslug
Old Oct 21, 2001 | 12:13 AM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
yah i know a couple people....hopefully they will do it for cheap
well thanks
Mods-
K&N Air filter
Bubbajones_ya
Jul 6, 2024 08:32 PM
Bohemian
Aug 15, 2017 05:11 PM
92firebirdguy
Sep 1, 2016 07:53 AM
Stryker412
Sep 20, 2015 06:59 PM
blackandblue02
Sep 10, 2015 08:19 PM
