Distributor Gear
Old Aug 31, 2005 | 10:38 PM
mike1986fyrbird's Avatar
Car: 1987 Trans Am GTA
Engine: 357ci Stealth Ram - Under Pressure
Transmission: Built 700r4/Pro Yank 3400 Extreme
Axle/Gears: 9-Bolt 3.27
Distributor Gear
I know you cant use a distributer gear from a non-roller cam in a roller cam app, because it will eat the gear because of the different hardness.
But heres the deal.
I have a non-roller block I am putting together and I want to reuse my distributer. Will I run into problems with this distibuter gear in a non-roller application?
But - I need a new gear anyways - Will one say.. for the application of a 77 Z28 with a 350 work? (its about $60 cheaper.)
Old Sep 1, 2005 | 11:05 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
You don't want to run a bronze gear on a factory-type roller cam. There's too much misinformation out there about "roller cam distributor gear" requirements - bronze gear ain't required.
The factory says with regard to crate engines that you need to use a "melonized" gear, p/n 10456413, with factory type roller cams. I don't know what drive gear you were looking at, but from gmpartsdirect.com it's $20.74 (list $41.46).
As for using a factory roller cam equiped distributor (melonized gear) with a flat tappet cam, no problem.
Why do you say you need a different gear anyway?
Old Sep 1, 2005 | 11:42 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
i'm using a 1986 distributor from a hydraulic non-roller motor in a roller motor now, but i have a crane cam, no problems here.
even if the rumor is true, it says a roller distributor can be used on the older non-roller cams, not the other way around.
Old Sep 1, 2005 | 01:52 PM
five7kid's Avatar
I'm using a ZZ3 take-off distributor in the '57, flat tappet cam. I swapped the gear over to my '86 CC distributor when I put the ZZ3 shortblock in the Camaro last month. Wear was normal. I would conclude there is no problem using the Melonized gear on a flat tappet cam. It is also possible the factory started using that gear before they started the roller cams.
I have a bud who used a bronze gear on a ZZ9 cam. It didn't last well, not sure how he intends to resolve that (he hasn't done much with the car in the last 2 years, health problems).
Old Sep 2, 2005 | 12:06 AM
Thanks guys that answers my question.
My stock gear looks pretty worn thats why I want to replace it, Everything else in the engine is brand new.
Old Sep 2, 2005 | 12:07 AM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
What type is the black gear? mine's black.
eightsixseven
Dec 16, 2024 01:50 PM
jklein337
Sep 19, 2018 06:23 PM
beastin91rs
Oct 9, 2015 07:38 AM
mddaniel
Sep 8, 2015 05:16 PM
86IROC112
Aug 17, 2015 07:57 PM
