new motor mounts = way too clode to Strut tower brace...need ideas
Old Oct 20, 2001 | 10:30 PM
Hecubus's Avatar
Car: 91 z82
Engine: 5.0
Transmission: pro-built 700r4: 2400 stall
I just replaced the motor mounts today and it put the intake WAY WAY too close to my Strut tower brace
I was thinking of making a small 1/4" plate to mount between the brackets and the wheel well to raise up the brace a bit
I think that will be my best bet ...
Any ideas on what I should do ???
anyone else run into that "being too close to plenum"
Thanks for any help
Hecubus
Check out my site http://www.geocities.com/hecubus91
91-Z28 305 Tpi "G92" mods-- K$N/Foil/Cat Back 3" Flowmaster/3" High Flow Cat/B&M shifter/ Intrax Springs/ Kyb Shock's-Struts's/Poly Bushings/Hotchkis Strut Tower Brace/Nos Wet Plate System currently ~ 175-200hp shot/ 255lph Fuel Pump/ Holly Adj. Fuel Press. Regulator/Digital Fuel,Air-fuel, voltage & Oil Press Guage's/MSD 6al/ Blaster coil/ Optima,Yellow top batt./Trans-Go shift kit
"I spent all my money on race cars, beer, and Broads... The Rest I wasted"
Old Oct 21, 2001 | 08:08 AM
ede's Avatar
ede
this is the second thread i've read in the last few weeks about replacing motor mounts and the engine sits higher. the other was ES poly mounts. no idea why it would raise the eninge, it shouldn't. to answer the question making a shim would work as long as you maintained hood clearance.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Oct 21, 2001 | 08:34 AM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
It might be worth trying to note which STB and engine mounts you have since this looks like this is getting common.
Old Oct 21, 2001 | 03:28 PM
Hecubus's Avatar
Car: 91 z82
Engine: 5.0
Ya sorry they are ES poly mounts
and a hotchkis brace..
just last night I was looking at the old mounts and the ES mounts are actually higher the the others as far as where the main long ~6" bolt goes threw it
the hole for the bolt is higher in the mount there for making the motor mount a little higher
If that makes any since....
Thanks for the help I'll make up a couple of plates this weekend
Hecubus
91-Z28 305 Tpi "G92" mods-- K$N/Foil/Cat Back 3" Flowmaster/3" High Flow Cat/B&M shifter/ Intrax Springs/ Kyb Shock's-Struts's/Poly Bushings/Hotchkis Strut Tower Brace/Nos Wet Plate System currently ~ 175-200hp shot/ 255lph Fuel Pump/ Holly Adj. Fuel Press. Regulator/Digital Fuel,Air-fuel, voltage & Oil Press Guage's/MSD 6al/ Blaster coil/ Optima,Yellow top batt./Pro-Built stage 3 700 R4/ACT 2400 stall converter/Trans-Go shift kit
Old Oct 21, 2001 | 06:06 PM
Guest
Guest
Posts: n/a
I think someone needs to call Energy Suspension in San Clemente and complain. Their trans mounts are too high, and now their motor mounts are too... are they just trying to make life difficult?
Old Oct 21, 2001 | 07:12 PM
JETHROIROC's Avatar
They're trying to make us have problems by not replacing all mounts at the same time, which is their recommended procedure. That really sucks.
1990 IROC 350
Mods: Too busy trying to make it run right to mod it.
Airfoil, Dynomax cat-back, MSD coil, 180 t-stat, Bald Eagle tires,
Hypertech fan switch, Accel 23# injectors, Holley module, ported plenum,
Ported Daytona Yellow stock base, Moroso valve covers, other stuff,
Streetdampr, Ruger P95DC, hot wife, new oil filter, !cats, !TBC, !AIR.
18.0 @ 85MPH since I'm one big-a$$ MF
"It's better to have and not need than to need and not have."
Old Oct 22, 2001 | 08:58 AM
Ed Maher's Avatar
Car: 04 GTO
Damn, if they're raising the engine enough to hit a hotchkiss STB then they are bringing the engine WAY up, like almost an inch or so. I have the hotckiss STB and with the crosspiece mounted low in the slots i have 1/2-3/4", if i raised it upo i'd have almost another 1/2"
Thats can't be correct engine geometry...
Old Oct 22, 2001 | 09:31 AM
99Hawk120's Avatar
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
Maybe this is what SLP means by needing new motor mounts with the 1 3/4" headers? New rubber mounts don't do a damn thing, maybe they are counting on you using energy suspension poly mounts that are much higher. HMMMM....
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
