rich or lean... do you know?
Old Oct 21, 2001 | 03:54 PM
firbird's Avatar
i have been having problems with my engine and it has been running really rich to where the pluges where completely black and i think i fixed that i dont know but i have a pic of what they look now. [img]https://firbirdgta.tripod.com//sitebuildercontent/sitebuilderpictures/good1.gif[img/]
if that did not work just go here
http://firbirdgta.tripod.com/cars/id8.html
but anyways i took a long cruise and and it did ok at first and then started to act bad at idle when i get stuck on red lights it would surge really bad and i would have to raise the idle up bye pushing the gas ,every 2 sec it twitches, a sudden jerk, and the rpms twitch too, the engine did not do it as much and it was not as violent if you raised the rpm, the rpm was at 900, too high in the first place and when i floor it, it shoots out a lot of smoke to where i could see it behind me in my friends headlights and he could smell it too. and when i do floor it it it boggs out really bad sometimes to where it seems like its going to die sometimes.
but the main q is the spark pluge in the pic too rich or lean?
350 w vortec heads, headders, auto, holley tbi, rpm manifold
[This message has been edited by firbird (edited October 21, 2001).]
Old Oct 21, 2001 | 04:51 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I would say the plug definately isn't rich or it would be black. A lean condition would be a white or clean plug right? I would say it looks like the engine is running lean, then again if this was a new plug and that's all that's on it, then it might be ok, because it's just starting to be worn.
"Rice burners are like tampons...Every pu$$y has to have one"
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
3" Hooker CatBack w/Aero Chamber muffler
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat, just switched to 180* b/c of winter coming and going to college in the mts.
3:73 Posi
Rebuilt 700R4
B&M Megashifter, 5" Autometer Tach w/shift lite
Old Oct 21, 2001 | 08:54 PM
firbird's Avatar
ok... i tonight i parked it and then i started it back up with the fuel pressure 1/4 turned for it would run a little bit richer and the tac is bouncing like crazy and it is running like crap so i move it back down and it still runs like crap.... , i have a 92 firebird so is it the coil messing up? i have checked the wire that the tac hooks up to but its still good. could the coil messeing up cause this??
Old Oct 21, 2001 | 09:46 PM
89Irocz23's Avatar
btt
Old Oct 21, 2001 | 10:05 PM
breathment's Avatar
put the comp in field service mode, drive it around and watch the check engine light, and it will tell you weather ur running rich or lean. i dont' know if u know how to do it or not, but in case u don't bypass the A&B connectors in the diag. port when the engine is running. the light should flash with 1 second cycles. when its in closed loop mode. if the light remains on for most of the 1 sec cycle. its running rich, if the light is off for most of that cycle, then its running lean. usualy when ur idling it runs kinda rich, and when ur reving the engine idling, it will run lean constantly.
if you do know what im talking about then good, if not and u have more questions just reply to this. or if i missed something, then someone else please add.
also, if u do jump those terminals, don't do it until the car is started, otherwise comp damage MIGHT occur. then take them out before u turn it off just to be sure.
- David
88' GTA 5.7L TPI MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series
http://www.geocities.com/david_angel_16
Old Oct 21, 2001 | 10:39 PM
firbird's Avatar
very interesting, i have never heard that, thanks!!! i will try, but be prepared to respond to some q's tomarrow
Old Oct 22, 2001 | 12:01 AM
Vader's Avatar
Firbird,
Breathe is all over this one. All I have to add are some more detailed instructions about the modes of the ECM in your car.
GM OBD I System Operation
This generation of engine control systems is a refinement of the first engine control computers and systems. First generation engine controls have some control over spark timing, a few output devices like the EFE system and EGR, and a minor role in fuel mixture adjustment. The OBD I system is designed to control and sense a wider range of functions than the earlier systems, including complete control of fuel delivery, and has proven to be much more reliable and effective.
The system has two basic modes of operation when the engine is running - Open Loop Mode and Closed Loop Mode. In a nutshell, Open Loop mode means the ECM is controlling the engine with essentially no feedback from the engine sensors - the control loop is said to be "open". Closed Loop mode means that the ECM sends control signals to the engine, scans the sensors for feedback to determine further corrections, then adjusts accordingly. The process is continuous, and the control loop is said to be "closed" since the sensors effectively communicate back to the ECM regarding the effectiveness of any adjustments made.
Open Loop Mode
When the starter is engaged, if the coolant temperature indicates less than 100°F and the intake air temperature is within 20°F of the coolant temperature, the cold start injector provides a spray of fuel or the cold enrichment subroutine allows longer fuel injector pulses on the service injectors. The cold start or cold enrichment subroutine is of eight seconds duration at a maximum. On a cold-start injector system the extra fuel is distributed to each cylinder via a air distribution system built into the bottom of the intake manifold. If the engine temperature is greater than 100°F, the cold start injector/subroutine is disabled by the cold start switch or ECM. Upon startup the ECM utilizes information in the PROM to establish the initial pulse rate for the injectors and the engine starts. At this time the engine is operating in Open Loop mode and will continue to do so until the engine warms up sufficiently to enable the oxygen sensor.
Closed Loop Mode
After a warm up period the ECM scans the sensors. If all sensors are operating and within their proper ranges, the ECM will enter Closed Loop operation. This means that the sensors are dynamically controlling the engine fuel and spark. The ECM receives information on intake air flow, coolant temperature, intake air temperature, exhaust gas oxygen content, barometric pressure, manifold pressure or vacuum, air conditioner status, power steering pump load, EGR operation, evaporative canister valve operation, engine RPM, vehicle speed, transmission gear selection, fuel pump status, combustion detonation, and throttle position. This information is used to calculate the proper ignition timing advance and pulse width for the injectors, and fires the injectors for the calculated period. This procedure is repeated continuously in very rapid sequence to maintain the optimum fuel air ratio. The electronic spark control components provide maximum advance, if engine knock is detected the spark is automatically retarded. This too, is a continuous process. It should be noted that the following components are matched for optimum performance - distributor EST module, ESC module, knock sensor and ECM PROM. These components are not interchangeable between 5.0L - 5.7L engines. In the event the information received is higher or lower than the normal range, a code will set in the ECM, and the Check Engine or Service Engine Soon lamp will light.
Block Learn / Integrator
The factory ECM/PCM has a learning capability which allows it to make corrections for minor variations in the fuel system to improve performance and driveability. There are two learning features. The Integrator and Block Learn (INT and BLM) and Block Learn Memory (BLM) cell. The INT and BLM feature is normal with a value of around 128 (the possible range is 0-255). If this value is higher than 128, it indicates that the ECM is adding fuel to the base fuel calculations because the system is running lean. A value lower than 128 indicates that the ECM is taking out fuel because the system is running rich. The integrator is a short term corrective action while the BLM is along term correction. The BLM value will change if the integrator has seen a condition which lasts for a longer period of time. There are from two to sixteen different cells which the ECM modifies, depending on RPM, airflow or manifold air pressure and other conditions such as AC on or off, etc. The ECM learns how much adjustment is required in each cell, retains it in memory, and applies these adjustments when the engine operates in that cell or RPM/Load Range. These features of the ECM allows the system to adjust itself constantly to your engine and assure peak performance for stock and other than stock engines.
NOTE: When the vehicle power is disconnected for repair or to clear diagnostic codes, the learning process has to begin all over again. To reinitialize the ECM, drive the vehicle at operating temperature with moderate acceleration and idle conditions for at least twenty minutes.
Performance PROMs typically change the parameters for fuel flow, fuel cut-off and spark advance-timing and will allow increased fuel flow and modify the spark advance curves during rapid acceleration. They can be programmed to tolerate differences in idle quality and manifold vacuum due to altered cam profiles and fuel systems.
Field Service Mode
On the OBDI ECMs, you can jump 'A' and 'B' terminals on the ALDL while the engine is running.
WARNING! This must be done after the engine is running. This is called "Field Service Mode" and will not harm the ECM.
If the ECM is in Open-Loop mode, the SES light will flash rapidly, about 2½ times per second. If it's in Closed-Loop mode, it will flash about once per second. When in Closed Loop mode, flashing less than once per second indicates the ECM is enriching the mixture above the 128 count base line. Flashing more than once per second indicates the ECM is leaning the mixture below the 128 base line.
Backup Fuel Mode
A 3.9K resistor installed between ALDL terminals 'A' and 'B' forces the ECM into Backup Fuel mode. This mode forces the ECM to use predetermined fuel calculations in the ECM PROM instead of the learned inputs in active RAM. This is more commonly referred to as the "Limp Home" mode of operation. Backup fuel is usually around 12:1 or richer from the factory.
Miscellaneous
An easy way to tell whether the PROM has been installed correctly in the PCM, and contains valid code set, is to watch the SERVICE ENGINE SOON light as you key on. Make sure the ignition is off for at least twenty seconds. Turn the key to the run position without starting the engine and watch the SES light. It should illuminate, then go out, then illuminate again and stay illuminated. This is called a SES light bounce. If you do not get a bounce then something is wrong and damage could result. If you try to start/run the engine when a proper SES light bounce is not present, then the computer will default to backup fuel and spark mode because it cannot execute a valid computer program. This can happen if the PROM is in backwards, or not seated, or contains a faulty program, or if the PCM has been damaged electrically.
Later,
Vader
If you want to beat the World, it might reach up and pull you down...
Adobe Acrobat Reader
Old Oct 22, 2001 | 02:54 PM
firbird's Avatar
Thanks Vader I appreciate all of these articles that you write, they have helped me out so much. And thanks breathment hopefully this will get my car working correctly!!
Old Oct 22, 2001 | 04:10 PM
breathment's Avatar
thanks vader for covering what i left out!
- David
antman89iroc
36
Jan 31, 2016 08:42 AM
Luigytico09
Oct 1, 2015 08:46 AM
James Sutton
Sep 23, 2015 02:18 PM
89fast5oh
Sep 8, 2015 09:55 AM
Jk_Under
Sep 8, 2015 08:13 AM
