Oil cooler & heater core hose routing
Old Oct 22, 2001 | 08:28 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I replaced the heater core in my GTA yesterday, and in typical fashion, I couldn't get that hose off that necks straight down and connects to the steel line that comes back up along the passenger side rail. I just bought a new piece of hose to bypass that steel line like I've done in the past, then I discovered that my GTA has the oil cooler, which T's off of that steel line. Instead of making a T, I removed the vacuum controlled valve that sits over the passenger valve cover and just wired the heater core and oil cooler in series. What purpose did that valve originally serve? What sort of negative aspects could develop from running the heater core and oil cooler in series?
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
Custom Thirdgen Subwoofer Enclosures
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Oct 22, 2001 | 10:06 PM
Jim85IROC's Avatar
ttt
The IROC Homepage
Old Oct 23, 2001 | 08:16 AM
crucial's Avatar
That's was the coolant diverter valve. When you switch your dash controls to "hot" vaccum is being applied to that valve and it directs coolant through your heater core instead of straight into the radiator. There will be no negative effects to what you did. My oil cooler has been off the car for a few years now and recently I put the heater core back in loop. During the summer I bypass my heater core but in the winter I put it back in the loop
1991 Z28 5.7 TPI
ZZ4 heads, ZZ4 cam, Harland Sharp roller rockers, Accel base, SLP siamesed runners, 52MM SLP Throttle Body, Hooker Headers, Flowmaster catback, MSD6A ignition, Home made ramair system, 2500 stall, bullet proof 700R4, aluminum driveshaft...
Soon to be installed. WC T5 !
Bubbajones_ya
Jul 6, 2024 08:32 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
scottmoyer
Sep 7, 2015 07:06 PM
apie2546
Sep 5, 2015 07:40 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
