intake blowing air instead of sucking air......
Old Oct 22, 2001 | 08:52 PM
84,86,88Z28's Avatar
whats the problem, i drove it a few days ago and ran great,and put it on a trailer yesterday,and it was everything it had to get onto the car dolly. and then got it to my dads,and started it to come off,and it no sooner than got off the trailer,and shutoff,never to start again. we tried and tried,tried timing,its got gas coming to it,and has spark,just wont start.....
p.s. its tpi 305 out of a 86 z28. with auto.
Old Oct 22, 2001 | 09:19 PM
Hulk0202's Avatar
My 305tbi ws doing something similar. I had fuel vapor and air coming from my tbi unit when I stepped on it. In my case the cat was clogged. Check yours, it may be the problem.
Old Oct 23, 2001 | 09:51 AM
82camaro's Avatar
Car: 82 camaro SC
Check the timing chain. Pull the distributer cap off and see if the rotor spins when you crank the engine.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, currant red metallic paint. Lots of other stuff...
82camaro
Ghettobird52
Jul 5, 2024 11:18 PM
1992 Trans Am
May 10, 2023 07:19 PM
BurlyChev
Aug 16, 2015 09:08 PM
kyle5647
Aug 15, 2015 11:56 PM
