running too rich ?
Old Oct 20, 2001 | 12:45 AM
88camaro's Avatar
running too rich ?
I recentley rebuilt the engine and i noticed i now get 16L/100 Km on an88 camar 2.8 v6
which is really allot, and also after i rev it to around 4000 and sharply drop the accelerator it backfires a bit which led me to believe it runs too rich is this the case , or do i have another problem ?
also when i use engine braking for a long time , lets say about 2 km in 3rd and sharply brake , the engine sometimes stalls.
what coud be the problem (its a 5 spd. manual.)
thanks
Old Oct 20, 2001 | 06:45 PM
88camaro's Avatar
can anyone please help
Old Oct 21, 2001 | 07:57 PM
88camaro's Avatar
comon i know theres someone here who has some sujestions , PLEASE RESPOND
Old Oct 21, 2001 | 10:28 PM
breathment's Avatar
do u know how to put the comp in field service mode? and by that u can tell if ur running rich or lean?
- David
88' GTA 5.7L TPI MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series
http://www.geocities.com/david_angel_16
Old Oct 22, 2001 | 03:58 AM
86 IROCZ28's Avatar
I am also interested in finding out how you check if running rich or lean. So how do you do it can you please describe. Is it by shorting out A and B on ALDL but then what do you do??
Mike
Old Oct 22, 2001 | 04:13 PM
breathment's Avatar
vader has a good description here of what i was trying to explain
https://www.thirdgen.org/messgboard/...ML/014763.html
- David
Old Oct 23, 2001 | 12:02 PM
88camaro's Avatar
so, let me know if i got this right
what i need to do is turn one the engine, connect terminals A & B and see if the check engine light flashes rapidly or slowly
where slowly means- too lean
and rapidly means - too rich
and after i find out how can i fix it if its running too rich/ lean.
thanks again for the replies
MustangBeater20
Oct 29, 2022 09:20 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
tmellott89
Aug 16, 2015 02:58 PM
squiggy2
Aug 9, 2015 09:30 PM
