How much lift w/ lightly ported vette heads?
Old Oct 23, 2001 | 09:19 PM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
I've got a set of corvette alum L98 heads which have been slightly ported and polished. Nothing is really enlarged, just sorta smoothed out. Actually the intake ports are enlarged, but my Accel superram base isn't matched to it so that probably won't matter. The heads have got Manley Raceflo valves 2.00" in, 1.60 ex, and a 3 angle valve job. My setup also includes the Accel intake (previously mentioned) and Edlebrock TES. I've already selected and installed my cam. So now I've got the option of using 1.5 or 1.6 rockers. The lift will be .500 .510 with 1.5 and .533 .544 with 1.6. Which should I get? I want max hp, but I don't want to overdo it.
91 Z28
Come see The Vicious...
Old Oct 23, 2001 | 10:42 PM
JPrevost's Avatar
Car: 91 Red Sled
Do you know if any work has been done to the valve guides? Find if they've been milled down or not. If yes, then go with 1.6's but I don't have the actual specs infront of me about the max lift on a stock height valve guide.
, Jon (350 TBI!)
91 Red My website
Old Oct 23, 2001 | 11:24 PM
Guest
Guest
Posts: n/a
The set I have left me with clearance for .517 lift, but not much more. .544 and you will be machining the guide down. The heads port stall somewhere in the .5 area depending on how much has been done to them, so going a whole lot more than that wont help much. I'd pick dependant upon if you want to do more work to the heads or not.
Old Oct 24, 2001 | 01:39 AM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
Well, the guy I bought them from said he had close to .600 lift on his vette so I shouldn't need to machine them, assuming he was telling the truth. His vette was supercharged too. The heads haven't been milled much. I had the machinist skim them so the head gasket'd seat better.
KCG
Jun 24, 2020 04:33 AM
PurelyPMD
May 5, 2016 04:57 PM
Nervous2
Oct 8, 2015 10:53 PM
TX-SleeperC5
Sep 24, 2015 03:13 PM
anesthes
Sep 21, 2015 10:24 AM
