Pulled code 42 whats wrong?
Old Oct 24, 2001 | 12:48 AM
NC 91 Z28's Avatar
Car: 91 Z28
Transmission: 4L60
I posted that my car failed two smog checks on another thread and now I find this. Plus my car is shaking a little what could be wrong any suggestions?
Black 91 Z28, L98, 4L60, Dual cats, Posi.
Mods: Slp shift kit,B&m tranny cooler,B&m 3-4 upshift kit,Performance distributors HEI Dyna module,Msd 6a,Msd 8.5mm wires,k&n air cleaners,Home made air induction,Modyfied Mat,Hypertech power coil,Hypertech 176/166 fan switch,Flowmaster cat-back exhaust,dual dynomax super converters,160 thermostat,Tb bypass mod,Tb air foil, KYB's.
Red 79 Z28 with lots of mods.
Old Oct 24, 2001 | 09:48 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Well, part of the smog check is to verify base timing...this requires that the EST bypass connector be unplugged.
When it's unplugged, a code 42 will be set.
To verify that this only occurs during timing check, reset the ECM then check for codes later.
Old Oct 24, 2001 | 02:15 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
wow, they actually verify base timing in CA before they smog you. Thats hella weak. Not that it can't be gotten around in the chip...but still, hella weak.
Old Oct 24, 2001 | 02:59 PM
u r sofa king we tah did's Avatar
no kidding. i had no idea that they did that in cali. that sucks.
Cornholio7979
Sep 20, 2018 02:31 AM
chazman
Aug 28, 2018 03:25 PM
chazman
Aug 22, 2015 02:01 PM
GouldyGTR
Aug 21, 2015 10:43 PM
